#16
94 Park Avenue Ultra 130K miles
130K miles
Battery. Alternator. Tires. Allignment Ignition module connector cleaned. Exhaust to Manifold doughnut. Wipers. Seat recliner worm gear regreased. R134a pound can. Belts. Carpet. Center console lid. Supercharger oil |
#17
Re: What all have you done to your Park Avenue?
Guess I'll add more too!
Timing chain set Water pump again Oil gauge sensor Another cam pickup magnet Oil pan gasket Did all this when changing timing chain K&N Filter as well. The K&N filter said it fit 96 to like 2002, I matched it with mine and it was a perfect fit. |
#18
![]() http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver)
#19
91 park ave ultra
~97000 miles, had for 6 years since 46000 work ive done replaced spark plugs/wires replaced rusted out freeze plug at bottom of engine block (made a thread about it) radiator flush/fill replaced starter (in parking lot of job site i was working at) replaced alternator replaced battery replaced wire connecting battery to alternator replaced struts on all 4 wheels - http://www.automotiveforums.com/vbul...d.php?t=462398 replaced seat belt latch replaced rear passenger window replaced driver side mirror turn signal springs near cam - http://www.automotiveforums.com/vbul...d.php?t=371963 work ive had done transmission rebuilt other misc transmission work crank sensor replaced cam sensor magnet replaced - http://www.automotiveforums.com/vbul...d.php?t=243511 water pump timing chain replaced motor mounts replaced (still broken, need to get fixed again) - http://www.automotiveforums.com/vbul...d.php?t=326662 tires replaced twice alignments and balancing oil changes, fuel system clean, other expected maintenance brakes need to fix motor mounts head liner upholstery various trim pieces loose crank sensor problematic ABS dented oil pan fuel filter keyless entry - http://www.automotiveforums.com/vbul...d.php?t=249926 and im sure theres more i forgot |
#20
'96 PA 104K mi-Cut the blue wire in the trunk lid to "hopefully" disable the alarm from going off inadvertently.
Besides that, nothing. But I've only owned it a couple weeks.
