What all have you done to your Park Avenue?
HotZ28 and Cntrysthbst thought of a great new thread idea: list everything you've fixed YOURSELF on your Park Avenue! So here it goes, I'm anxious to hear what everyone else has had to do to their PA also, so post away!
1992 Buick Park Avenue: Replaced heater core Fuel filter, plugs and wires (done twice each since ownership) Oil/filter change (countless times, regular basis for me) PCV valve Air filter Radio (original was sold before I bought the car) 02 sensor (replaced twice, now it's the circuit that's bad, not the sensor! )Battery Battery cables Engine coolant Upper radiator hose Lower radiator hose Both heater hoses COUNTLESS fuses during an electrical crisis Sylvania silverstar headlights R-134a refrigerant (I learned how to retrofit with this car, it was originally R12) Rear view mirror (replaced with factory electrochromatic mirror) Replaced heater core (TIME CONSUMING!!!! Needed a 12 pack for this one) Complete detail, including every nook and cranny in the engine compartment! Radiator fan relay (low speed) Faulty cigar lighter circuit (caused A/C to turn on whenever any door was opened!) Installed Concert Sound II speaker housings Installed custom dome lights for the rear (inner c-pillar panels) Driver door power window switch Power Antenna (is it me, or does it seem like the power antennas just don't last long in these cars?!) Left side passenger door shell (original had been torn apart by a semi's lugnuts going over 60 mph) Driver and passenger side door lock actuators (PITA!!!!!!!!) Starter (original starter had 140,000 miles/ 13 years old!) Alternator (turned out this didn't need to be replaced, the ECM was the overcharging culprit!) Cleaned evap. core Wipers (regular 6 month change) Thermostat replaced Overhead console (2) Plastic doesn't make perfect in Park Avenues! Visors w/ vanity mirrors Cup holder (another non-perfect plastic part) Driver door red door panel warning light.....I'm starting to hate plastic! Dash speakers (if you own a 91'-96' model and possibly even a later model then you know that the sun KILLS the dash speakers!)
![]() http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver)
Re: What all have you done to your Park Avenue?
1997 Park Avenue (51,000 miles)
Oil & Filter changes Sticking throttle plate Recharge A/C (R134a) Coolant level sensor (bad connection) Replace right rear bumper chrome (plastic) trim piece Replace weather strips on lower edge of doors Still working on the door lock delay problem (see other posts) |
I'll post later but am close to yours Loekee75,
will be interesting!
1997 PA (68,000 miles)
Replaced Evaporator Core (ouch!!!) Oil pressure sensor Power Drivers Seat motors replaced (ouch!!!) Oil Changes/Filter Battery Replacement New Tires New Brake Pads (I need some new rotors too I think) What I hope I never have to fix??? Anything electrical Suspension Another Power Seat |
Ok, lets see-
Regular maintance stuff oils, air, fuel, trans, filter, etc.. Tires - all 4 Rotors both Drums both Shoes and Pads Calipers both Wheel cylinders - both Master Cylinder Rubber brakes lines - all 4 Struts and mounts Springs Air shocks 12 Sub-frame bushings Transmission mount Engine mount Dog-bone mount And that mount by the big cooling fan The Rack and Pinion Outer tie rods - both Exhaust gasket/donut Exhaust holder uppers - the rubber O-ring things that hold the exhaust up Plugs, wires, pvc, Battery Positive cables from battery to alt and assc. Negative cable Alternator 5/6 times till got the Delco one Drive belt 3/4 times till replaced tensioner Tensioner Waterpump Cooling fan temp switches - the things mounted on the big fan Thermostat 3/4 times till replaced radiator Upper radiator hose Lower radiator hose Radiator cap Trunk seal Drivers side rear light housing - it was leaking water into trunk All 4 center hubs for rims - they were shot Front splash shield - thing under the bottom front ALL light bulbs in the entire car - had elec. drop/problems with wrongs bulbs Keyless entry module box Rear view mirror with compass - replaced the one without compass Two heated leather front seats Radio Cass/CD player factory Lamp moitor Headliner Inside visors/sunshades Cluster Replaced both keyless remotes Bought an extra key for ignition - 45 buks at dealer! Window switches - whole unit with the power seat, mirrors, etc. Heater core Drivers side heated mirror Emergency brake lever housing Drivers side rail guide for window - it was rusted/broke Oxygen sensors Crank shaft sensor Cam sensor All three coil packs Power steering cooler Power ant. for the radio Radiator - it also cools the engine oil, oil lines run to the radiator as well, and has the low coolant sensor on it. Have added to car ----------- Big transmission cooler Ventvisors Radar det., navg. tinted windows at 5%, except front windows they are 15%, yes legal here in Fla. where I live I don't dare add these receipts! Alot of these repairs are because I'm picky, I want everything in good shape and working good. A few more is because I'm two blocks from the ocean. Salty, thick, humid, hot air, it rusts things quick. Yet I still have a clunking over bumps which makes for poor ride and steering, and code 41. Hopefully all these repairs will pass and I can enjoy the car. |
I'll leave it simply at what haven't I done
That was a good laugh I needed!!! Thanks wrightz28. Looking back at all that is making my head hurt. I got a different perspective on this car now.
I need to add: Today...trip from Springfield IL to Peoria IL
2 new 60R16's (one blew a belt from SPI to PIA) Firestone did me right for $181 Im on my way to Milwaukee tomorrow.....hope nothing else!!!! |
Ed '95 Park Ave Ultra '76 Jaguar XJ-S '06 Toyota Avalon XLS |
mine slides on and off the base attatched to the windshield so all taht was replaced was the actual mirror and housing
'97 PA Ultra with 135,000 miles. Shortly after getting it, I changed the supercharger oil, replaced the spark plugs, changed the engine oil to Mobil 1 full synthetic, topped off the A/C refrigerant, treated the door seal and underhood weatherstripping with dieletric silicone grease as recommended by the owner's manual and factory shop manual, and changed the cabin air filter. Also had a leaking fuel line replaced, but didn't want to do that myself, so I had the dealer do it.
Still to do: Brake job and turn or replace front rotors Replace fuel tank sending unit Replace oil pressure sending unit |
1994 Buick Park Ave. Ultra Service Records
35,101 miles (5/15/97) - New spark plugs - Coolant/Transmission flush 48,910 miles (1/20/98) - Replaced master door switch - passenger rear window switch was not working on master driver switch - Replaced door lock actuator - front door lock not operating with keyless remote - Replaced rear wheel cylinders - leaking 50,136 miles (4/01/99) - Replaced battery (6 yr. warranty) 57,457 miles (5/11/04) - Recharged refrigerant and added black die for future leaks 57,821 miles (8/17/04) - Bought car for $6,100 (incl. tax) - New tires – 225/60/16 Kelly Navigator Gold (Belle Tire) 59,000 miles (9/04/04) - Fram Air Hog filter - New PCV valve - New fuel filter 60,100 miles (9/27/04) - Changed supercharger oil 68,000 miles (3/7/06) - New right wheel bearing - $144.16 (part) + $10 (labor) 78,301 miles (6/01/06) - Coolant/Transmission flush’n fill - New left bearing - $144.16 (part) + $20 (labor) - New PCV valve ...and now i'm off to buy a ambient outside air sensor because it reads 115 degrees at all times. lol...it never ends i tell ya!
Adding to my list:
*New rotors (not drilled or slotted ...... cheapies for $25 apiece*Ceramic brake pads ($33 from the zone) whoever says ceramic pads don't brake well until hot haven't driven my car with them! *Catalytic converter ($212 installed)....gone is the exhaust smell....not to mention a MUCH quiter and smoother ride
2002 PA w/40K
Thermostat Cabin air filter Frontbrakes (at 24K miles, imagine that) |
