Old 05-04-2002, 06:33 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
But how would I get 12v of power to the LEDs, since they can't run off 3.2v? I need them to get 12v of power when they light, but to ONLY light when my alarm LED wire sends a signal to them.
Let me try to answer your question according to the simple but clearly understandtable schematic CXHatchback drew (great job CX !!). However, CX made a tiny mistake on the description on the schematic. The terminal on the "coil" side that connects to the alarm LED should be the negative side instead of the positive.
A relay in this case is connected in series with the 3.2V alarm LED and used as a singal (or power) to electrically charge a coil of wire.
When the coil wire is electrically charged, it will create a magnetic field that pulls down on the "common" terminal metal plate and connect to the normally open terminal which carries negative (ground). This way it will provide ground to the 12V LED that connects to the battery voltage and turns on the LED.
Do you mind telling us what is your project with the LED?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 05-04-2002, 06:42 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
You must have missed this part, I covered that.
Originally posted by CXHatchback
This is assuming that the alarm LED is constantly grounded and is connected to a power source onyl when the alarm is activated. IF it's the opposite, that is, it's constantly connected to the positive end, and is only grounded when the alarm is activated, then you have to switch the terminals on the coil. Instaed of grounding it, connect it to 12V+, and the other end connect to the 3.2V LED negative.
Old 05-04-2002, 07:07 PM
Tofuboy's Avatar
CX--You beat me on the post right after SilverY2KCivic ask about the explaination.
There seems to have a problem on the power supply to the project LED that silver is working on.
In this case the relay will be connected in a parallel circuit and will only allow the 12V LED that you are working on to light up when the alarm LED lights which will turns on and off the power to your project LED (flashes).
Acctually the flashes will occur on my theory also (assuming your alarm LED is the constantly connected to ground type).
If you want your project LED to have constant power when you turn on your alarm, you should not connect it to your alarm LED wire. This will require another way of wiring and different voltage of relay.
Let us know if you need constant power to your project LED when the alarm is activated.
95 Civic EX
83 Toyota Starlet
Old 05-04-2002, 10:54 PM
I think it all depends. I know what you're saying, but sometimes there are flashing LEDs. We just have to find out if it's a flashing LED or if power is being turned on and off to the LED. Most likely it's a flashing LED and the schematic will work well. Has he tried it yet?
Old 05-05-2002, 03:20 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Ok, screw it, it'll be better figured out if I just tell what it is. I'm trying to hook up a pair of washer nozzle LEDs to flash with my alarm. These LEDs are meant to be constantly on, and not flas that I know of. But any LED can be made to flash, because I used to have a pair of screw LEDs attached to my mesh grill, and they flashed with my alarm (but worked when tapped into my alarm LED line) and they were also made to just be on constant, but they flashed just fine. I have a Clifford G4 alarm, so I dunno how the LED for it works, weather it's constantly on till the signal is to it, but when my alarm is off, the LED is off, and when it's armed, the alarm LED blinks. Wait, so that means it DOESN'T get a constant signal. LOL! I'm such a doof. Ok, so it's only constantly on when I have my alarm in valet mode, but that's irrelivant since the washer LEDs would be activiated when my alarm LED is activated to light up. So alarm LED blinks when armed, off when disarmed, and constant on (no blinking) when in valet mode. Damn I hope this info helps you all out to help me figure this mofo out. :alien2:
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-05-2002, 09:45 AM
That's perfect. So you need to use regular LEDs (not flashing) for your washer nozzle things, and since the alarm LED is regualr too, just connect them like the diagram shows and you should be fine.
Old 05-05-2002, 08:29 PM
Cali Guy
Cool then, thanks d00d!
hessemer69 on AIM
Old 05-06-2002, 03:51 PM
93speed's Avatar
93speed 93speed is offline
It would be really cool to get an inverter and somehow hook it up to one of the lights so they blink like a railroad crossing.
I'll have to figure that out
93 MR Civic EX - EJ1
Old 05-06-2002, 06:54 PM
That's not an inverter you want, it's a relay. Or possibly series of.
Old 05-06-2002, 07:43 PM
93speed's Avatar
I just used the word inverter to keep it an original idea
I'm in an electronics class at school so I'm sure we could figure something out.
Old 05-06-2002, 10:16 PM
Cali Guy
CXHatchback:
I sent you a PM< but not sure if you got it or not.
For the relay that I need to get, do I need a specific kind, or type, or will any 4 prong 12VDC automotive relay work for this? Thanks.
hessemer69 on AIM
Old 05-06-2002, 11:41 PM
I already replied to your PM, you don't need a 12V relay, you can't use it. You need a 3.2V relay, or something close, that matches the voltage on the alarm LED.
Old 05-07-2002, 01:41 AM
Cali Guy
Ok, I'll get the one in the link you posted up then, I was just thinking 12v relay because of the 12v line that will be going into it. But you're the expert here.
hessemer69 on AIM
Old 05-07-2002, 11:09 AM
Hehe, cool. Yeah, as far as I know, that should be perfect.
Need HELP! Try to start and electrical system goes dead. Turn on head lights and the. klein444 Crown Victoria 10 08-26-2018 01:23 PM
need help plz with wiring on a 325ci .. intake wires.. ladagosta 3 Series 3 08-22-2010 10:53 PM
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 07:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
I am new tot he forum and am in need of some majr help with wiring and fuses. dorfboy Mustang Talk 3 04-07-2005 01:41 AM
