Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 08-21-2010, 02:04 PM
ladagosta's Avatar
ladagosta ladagosta is offline
need help plz with wiring on a 325ci .. intake wires..
I need someone with a wiring diagram to help with 2 wires we can not find the port on one and one wire had no plug connected to it.. once we are past that, I know it will start she has contact now but no lift off until those 2 wires are resolved.
this wire is all alone and cant figure where it snapped off.. a beige with a white stripe wire.. under intake on emission control
base color of the 3 wires are solid tan and solid yellow and red with white stripe with a black clamp with yellow inside the tab the prot is not in sight and I have looked at every angle possible.. can not locate it..
the port is oblong with a click on plug not a uclip like most of them..
they are located under the intake toward the emission control unit hope this helps....plz anyone with a diagram or wiring schematic..
I would be so glad to get this thing out of my driveway.. not fun working on cars with no lifts and glorifed equipt...
these might be better pictures:
http://i262.photobucket.com/albums/i...821001420a.jpg
http://i262.photobucket.com/albums/i...0821001420.jpg
why do they put the starter where no one in their right mind would attempt to replace it....unless they have a lift avail...
Old 08-22-2010, 01:07 PM
venzon venzon is offline
Re: need help plz with wiring on a 325ci .. intake wires..
One wire, I have no clue at this time. It would help if you find out where it's coming from. The connector, my guess would be the one that connects to the MAF sensor. BTW, I don't have my 325ci anymore.
Old 08-22-2010, 09:46 PM
ladagosta's Avatar
We got her running today ... after . i removed the intake and found them the one was between the starter and the canister underneath the starter hard to see if you dont have the intake off and the other was also under the intake.. have them both on and needed to buy another set of plugs.. NGK never ever put autolites in these cars.. not worth it . I knew it when i bought them but they didnt have any NGK so I did what i had to do,, now they will sit in the trunk for emergency back ups and nothing more.. thanks for offering to help but car is running perfect and out on the road again TG@@
Old 08-22-2010, 10:53 PM
Glad to hear she's back running. Thanks for the update...
