Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-06-2002, 06:10 AM
Neil82's Avatar
Neil82 Neil82 is offline
Send a message via ICQ to Neil82
Thanks m8 I promise that I will scan the dyno in tonight when my bro gets back from work, and he can show me where he has hid the software for it
Used to have a :
Nissan Primera 2.0 SRi-GT
'97 Bronze Primera SRi
Now have a Clio 172 Cup
Old 02-06-2002, 11:44 AM
Anthony Anthony is offline
Like I said on Messenger, they are some pretty impressive numbers.
The torque figure is very impressive, although your engine seems to have trouble at high revs (hence max power is only at 6050rpm) which is going to ultimately limit the bhp you get (since bhp=torque*rpm/5250).
Once you get the car properly mapped and the Hotshot header installed, hopefully that will sort out your top end breathing problems and you should be outputting some impressive figures indeed. I reckon that you should be able to make power for another 300-400rpm at least.
And yes Neil, you have a faster SRi than me, OK? :o
And of course, happy birthday, and I'm sure you'll enjoy your "present" tonight
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 02-06-2002, 11:59 AM
TeamNissan TeamNissan is offline
Send a message via ICQ to TeamNissan Send a message via MSN to TeamNissan
Looking forward to see youyr Dyno!
This is just an idea, but have you tried to download the SW for you scanner on the internet!?*LOL* It is the worlds biggest storage place!!
NISSAN RULES...........
http://www.nissanklubben.dk
Old 02-08-2002, 07:31 AM
Neil82's Avatar
here is the dyno sheet, the P@wheels figure seems a bit low but most of the big power cars at the dyno meet did the same for some reason!
Used to have a :
Old 02-08-2002, 08:15 AM
Hey Neil,
Nice figures.......
But how come your car already cuts off at 6200 rpm!?
Old 02-08-2002, 08:33 AM
We had a Primera 2.0 from 97' that made the same with the torque graph around 4200 rpm.
We found out that it was because of a worn chain drive and chain "controller" (don't know the English word*LOL*) - After we changed the parts the torque line was all flat out!
Old 02-08-2002, 08:44 AM
RCer's Avatar
RCer RCer is offline
Originally posted by P11GT
Neils Sr20 is factory 130 BHP at the flywheel, its not the 150 BHP SR20 so an increase of 15 BHP above standard, not bad at all.
I did'nt knew about that engine. Why so low on power?
Americo
2000 Primera.
Old 02-08-2002, 10:13 AM
Neil82's Avatar
It's the engine they put in the lower versions of the Primera like the GX,SRi etc it actaully has 128 hp (130 ps) and the P11 GT has 148 hp (150 ps). Its basically the same as the GT but with more restrictive exahust etc to restrict power.
Used to have a :
Old 02-08-2002, 10:15 AM
Neil82's Avatar
TeamNissan the reason it stops at 6200 is casue thats when the power drops off so they dont bother reving it any further. When i get the hsh on ill get it dynod again but this time get them to redline it to 7100.
Used to have a :
Old 02-08-2002, 10:17 AM
Neil82's Avatar
What ya talking about the flat spot in the torque? Kevins Primera GT had the same flat spot as me the only way to sort that is a 'uni-chip' which i will be fitting as soon as I can.
Used to have a :
Old 02-08-2002, 10:22 AM
Neil82's Avatar
I think there is a possibility your car may have the 128 hp engine?
Used to have a :
Old 02-08-2002, 11:19 AM
RCer's Avatar
My primera is a GX, but it has the 145hp, I have race a VW GTI (1.8T) and have lost only by have a car lenght.
What makes you think that? How can you determine the diference between the 2 engines? Do you have any pic of your engine?
Americo
2000 Primera.
Old 02-08-2002, 01:21 PM
pche059 pche059 is offline
Send a message via ICQ to pche059
WOW..145hp at crank only gives 99whp?
what about those ppl like jason that has 141whp? that's 50whp over it....
they must be doing over 200hp at the crank?
Patrick
99 Primera P11
One stripped down Primera
Old 02-08-2002, 02:11 PM
aaaaaaaaaaahhhhh OK just found it strange!
Anyway mine already cuts off at 6800
Old 02-08-2002, 02:15 PM
Damn you have a LOT of mods there Neil!
Yep the flat spot on the torque!! We found out, that because it was worn the timing was a little off, so we changed the chain "things" I wrote about before and the graph was continous without the flat spot!
My Dyno Results SiRII '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 05-19-2003 12:20 AM
Performance parts for the US Evo...and dyno results! VQuick Lancer 1 03-20-2003 04:01 PM
Dyno results of my 2k supercharged Maxima Y2KevSE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 19 12-27-2001 03:02 PM
Hi all.....Perth Dyno results... Pva_Glue General Discussion 20 11-19-2001 09:40 AM
Dyno Results! Dissapointing...or is it? G-Forces Engine 27 08-01-2001 08:04 AM
