Old 04-26-2004, 05:37 PM
tasteph tasteph is offline
On my recently purchased '96 Windstar I had same problem but I think I've got mine fixed. I've seen other postings that suggested start engine and then open/close one door at a time. I aslo sprayed WD-40 on all doors. It appears that the driver's door was the one that was the problem.
Of course a "dealer" is going to charge you an arm and leg to fix the problem. They might even ask for a couple of fingers and toes too!
Old 10-06-2016, 03:47 PM
Windstar Star Windstar Star is offline
Re: Ford windstar dome lights problem
I have had this issue for a long time! Finally read the forum, got some ideas and fixed it. I used a drill mounted wire brush and cleaned off the four contacts on the side sliding door and the four on the door post. I opened the hatch and operated the little spring sliders on the sides of the hatch door until the dust stopped coming out (compressed air would probably be better). I then sprayed these, the hatch door latches (right above the spring sliders), and the contact points on the side sliding door with WD-40.
VOILA!! 20 seconds after door close, the lights turn off!!!!
Thank you car forum!!
Old 10-07-2016, 08:09 AM
phil-l phil-l is offline
To others reading this: I would *not* use a drill and wire wheel to clean the sliding door contacts; the metal is very thin and won't tolerate much abuse. I've found that Revere Ware cleaner (that's right, for copper-bottom cooking pots) does a good job removing the tarnish and dirt that these electrical contacts pick up. You'll get longer-lasting protection for these contacts than WD-40 by using dielectric grease, found at any auto parts store.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
2000 ford windstar master lighting switch light kilroy357 Windstar 3 08-06-2021 12:52 PM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
I love the Ford Windstar 1999 serge_saati Cars in General 0 05-09-2009 02:51 PM
1998 Ford Ranger- dome light stays on- timer switch-where? petehanna Ranger | Courier 4 10-16-2006 07:18 PM
ford windstar abs light and traction control light andyrobinson26 Windstar 0 10-16-2005 08:30 AM
