Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-28-2013, 09:08 AM
Tsschnare Tsschnare is offline
Re: 2.4 L engine timing chain noise
I have a similar noise mainly around 3 rpm but it was never there and it just came after I down shifted 2 days ago
Old 10-28-2013, 03:04 PM
Tech II Tech II is offline
I think there was a TSB for 2001-2002 2.4's, where there was a problem with the chain not getting enough oil....the orifice hole that lubed the chain could get plugged...also a potential problem with the tensioner....this would cause a slapping of the chain......
You would get a timing kit....new chain, new tensioner, new cam sprockets, new crank sprocket, new orifice(larger opening)....
Old 03-25-2015, 09:45 PM
savast2769 savast2769 is offline
I just started hearing this rattle, knock or tap in my engine. When its cold it runs like a dream. As soon as it starts getting up to temp or above 2000 rpms it does it and gets worse as it reaches temp. I would like to try and pin point issue before blowing money on this car. Can anyone help????
Old 03-26-2015, 01:04 PM
You have to isolate the noise first...top end, bottom end, or from the front cover....
Old 02-22-2016, 12:59 PM
Sunhawk01 Sunhawk01 is offline
Pontiac Sunfire Sport 2000, 2.4L
have the same problem with the clicking noise....but also the vehicle has no acceleration power. if I push the gas peel to the floor...it won't accelerate and will only move slowly...about 10-15 mp4 max...the timing Chain was repaired 2 times before but after just replacing the alternador, this occured. I changed the 2 electronic coil packs and the control module and the car ran like a champ for 4 days....now I am back with the exact same problem before. is it the timing chain?
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 02:56 PM
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 07:21 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
96 2.4 dohc timing chain/timing question camarocasanova Grand AM 1 03-15-2007 09:32 AM
'98 Max with Engine Timing Chain noise...Help!!! imports_only1 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 11 05-01-2004 09:37 AM
