Old 10-23-2003, 10:05 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
can i also add that if you use the microsol directly onto the car body b4 you lay the decal then it will conform to even tighter angles, i have used this a few times on larger sheets. hoods are still so difficult to do without a wrinkle.
Old 10-24-2003, 02:34 PM
Bangai-o's Avatar
Bangai-o Bangai-o is offline
I think it's be good if people would add pictures and state the type and brand of decal they've used because each brand has different colouring and types which can be confusing to get the right one.
Ferrari 250 GTO Progress. Porsche 911 GT3 Complete.
Old 10-24-2003, 02:45 PM
freakray freakray is offline
AF Modelrater
Re: How To: Working With Carbon Composite Decals
That's one reason why I put the first image above, to show some different patterns, those are also the ones I work with and that I have used the method I outline above on.
AF User Guidelines
Old 10-24-2003, 02:49 PM
bigfrit's Avatar
bigfrit bigfrit is offline
Thanks a lot for the more then comprehensive tutorial!
Now I have got no excuse to try this also !
cheers
Olivier
Old 10-24-2003, 07:12 PM
T\/\/iN-Tu|2Bo's Avatar
T\/\/iN-Tu|2Bo T\/\/iN-Tu|2Bo is offline
Thumbs up
Excellent tutorial
"If you feel in control. You're not going fast enough" - Mario Andretti
Old 10-25-2003, 07:36 PM
nismo man's Avatar
nismo man nismo man is offline
solvaset or micro sol
where can i get some solvaset or micro sol and which is better.
Nismo Man
JGTC
Old 10-25-2003, 09:46 PM
AF Modelrater
Re: solvaset or micro sol
It's best to get the Microscale products, being MicroSet and MicroSol, they are designed to work together.
You can get both from Dennis at www.modelexpress.net
AF User Guidelines
Old 12-01-2004, 06:22 PM
ATMDC's Avatar
ATMDC ATMDC is offline
after cutting the tape mask, did you stick it right down onto the carbon decal? i thought that when you would try to pull it back off it would rip or mess it up?
Old 12-01-2004, 06:34 PM
Jay! Jay! is offline
Horizontally Opposed
Ray specifically calls out the fact he uses Tamiya tape because of its low-adhesion. That's what makes it less likely to stick "hard" enough to damage the decal.
If you're uncomfortable with sticking tape onto your expensive decals, simply take the extra step of transferring the tape pattern to plain paper, cut out the paper, then use the paper pattern as your guide for cutting the decal sheet. you may still want to secure the paper pattern to the decal sheet in at least one inconspicuous point, so the pattern can't move once you've started.
edit: That's what Bill said, too:
Originally Posted by bvia
2. Transfer the masking tape template to a piece of cardstock (3x5 notecard is usually a good size and thickness) and use a pencil to trace the outline onto the decal (IF the part is symmetrical, trace on the back, or paper side of the decal). That way you can keep the template for other pieces (racing seats are almost identical in certain series) and also sometimes the masking tape can simply destroy the decal when you try and remove it.
Hierarchy of Subaru:
(Click to see mine!)
Old 12-01-2004, 06:38 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
This is a great tutorial Ray. for many reasons. ive been having trouble with my decals on the Silvia in Motorsports. ive never had to use Microsol before and wasnt sure how to use properly without damaging decal. this is a GOD sent thanks.
Old 05-20-2005, 02:02 AM
emilmh emilmh is offline
there must be an alternative solution to micro sol?
I cant find it where i live!!
can anything else be used instead like, methelated spirits, mineral turpentine ect??
since i cant find microsol i might not be able to complete my model!
Old 05-20-2005, 02:54 AM
RallyRaider's Avatar
Zomby Woof
Definitely not turpentine. There is probably some household alternative if you knew the formulation. I always wondered if vinegar would work in place of Microset. Never felt the need to try personaly.
Old 05-20-2005, 07:56 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
I notice from your proifile Emilmh that you're from Australia. I know there are others on this forum from Australia, so maybe they'll let you know where to get some.
Old 05-20-2005, 11:27 PM
Re: Re: How To: Working With Carbon Composite Decals
yeah its a crap country
fellow aussies, any help?
Old 05-21-2005, 01:28 AM
Zomby Woof
Re: Re: Re: How To: Working With Carbon Composite Decals
Couldn't dissagree more...
There aren't many decent hobby stores in Brisbane. Best bet is to try Hobby One in Mount Gravatt. They might have something. I know Vogler and Son in Ipswich carry some decal solutions as well.
If they can't help you then the internet is your best bet. I live in the middle of country NSW and get most of my goodies that way.
How to: Polishing with Meguiars Scratch X CADguy Car Modeling 30 05-11-2005 10:26 PM
How To: simulate carbon fibre with paint Zcaithaca Car Modeling 25 11-26-2003 06:07 AM
Carbon fibre decals, how to apply? yellow15 Car Modeling 29 07-08-2003 05:13 PM
Need Help with Seat Harness's and Carbon Fiber Decals tc3house Car Modeling 0 05-28-2003 07:20 AM
