Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-30-2004, 05:57 AM
wrigley123 wrigley123 is offline
UPDATE.......got the 2003 tacoma back from the dealership with a new rear differential. The CLUNK is still there! It actually sounds louder. The truck is back at the dealership (they were nice enough to give me a loaner). More to come!
Mike
Old 11-30-2004, 10:31 AM
lifetrddeath lifetrddeath is offline
Send a message via AIM to lifetrddeath Send a message via Yahoo to lifetrddeath
Re: Transmission Bump/Thump??? At Stops
Originally Posted by wrigley123
My 2003 Mini 4cyl 42000 miles is currently at the dealership having the rear differential replaced. The "CLUNK" has been noticeable for about a month. There were no signs of anything wrong with the truck other than the "CLUNK". I only heard the noise after the truck was warmed up. The dealership did not hesitate to tell me that the rear differential was bad and needs to be replaced.
Mike
Dont be suprised if after a little time the problem comes back.
Old 12-01-2004, 12:08 PM
UPDATE #2......The dealership has now decided to give me a new transmission. I'll take it!
Mike
Old 12-01-2004, 09:23 PM
Mike
And again, it may still come back!!! It's just a problem Tacos have.
Old 12-09-2004, 12:04 PM
ANOTHER UPDATE......New transmission has been installed. Haven't really noticed a difference.
Mike
Old 12-09-2004, 12:11 PM
Ha, new tranny, still bumping around when coming to a stop light, then going again, told you it'd still be there. You need to lube the hell out of the connection between your tranny and drive shaft. Then you need to do an add-a-leaf to the rear end. Depending on what model you have, there are traction bars for your tacto that when combined with the AAL have shown to completely get rid of the problem you're having. I'm going to do it to my Taco soon enough because axle wrap is a pain in my ass.
Old 12-09-2004, 05:31 PM
S/C Prerunner S/C Prerunner is offline
He's right. Lube it and install the ADD-A-LEAF. Then when it starts again...Lube it again.
If I'm not haulin' ass in my S/C Tacoma, I'm Monster Truckin' stuff with my Jeep!
Old 12-10-2004, 06:39 AM
Lube what connection between the tranny and drive shaft? There are no zerk fittings anywhere on the driveshaft. I have indicated this in past posts. Well........I guess the "CLUNK" is meant to be there. I did get a new tranny and rear differential out of the deal at no cost to me!
Mike
Old 12-10-2004, 12:07 PM
Mike
true, new stuff is good. but maybe you don't understand the seriousness of the problem... axle wrap can unexpectantly brake your driveshaft!!! Plain and simple. I know a guy buy me, who had his Taco still under warranty, the dealer actually UNDERSTANDS the problem and basically did an OEM Toyota AAL. With greasing it got rid of the problem.
Here is a pic of the connection, where like i said the tranny connects to the driveshaft via a U joint. In the pic, back of tranny on right, driveshaft to the left. Also below I added a link that is a maintenance tech for a 4Runner, but it's the same situation as the Taco, so read up, look at the pics.
http://www.4x4wire.com/toyota/mainte...tml#driveshaft
Old 12-13-2004, 06:07 AM
There is NO grease fitting on my truck!
MIke
Old 12-13-2004, 11:47 AM
MIke
So you're telling me you have no U joint on your 2003 that connects the driveshaft to the transmission? News to me.
Old 12-13-2004, 06:57 PM
Re: Re: Transmission Bump/Thump??? At Stops
No.....what I'm telling you is that there is not a grease fitting anywhere on the U-joints in a mini tacoma. They don't exist! Of course there are U-joints......but NO grease fittings!
Mike
Old 12-13-2004, 07:04 PM
Well in the pic i provided a post or two ago, starting from the left, the first round nut looking thing you come too, it's called the slip yoke, that's what you grease the hell out of. It doesn't hurt to grease that entire joint either. Just stick the grease gun, or get your fingers dirty and work it in there, all over. Once you start seeing old grease coming out, put some more in, then you should be good.
Old 12-19-2004, 08:32 AM
wiz706 wiz706 is offline
update 12-19-04
i am still having the same prob with my 1998 taco extra cab..
dealer said its normal but not like this... going to try add a leafs to see if its the springs. i called a toyota parts department and the orignal springs(3 leaves) are no longer avail only the new(4 leaves)
sounds like their trying to cover somthing up..
daniel
middletown ny
check out this link again the more the better
http://www.thesqueakywheel.com/compl...plaint5483.cfm
thank you
i installes the ad a leaf and the bump is all gone
looks like toyota has weak springs.
i work for a auto parts dealer(ford)
and checked with a friend in toyota and found out that the original 3 leafe springs are no longer aval you have to update to a 4 leafe spring....
kind of interesting... string you along untill out of warrenty and then bang $600.00 spring replacement
please check the link again
Old 12-19-2004, 08:46 AM
yes this is the rear slip joint and the problem is called axle-wrap. this has to be one of the most common problems with tacos. i've heard untreated, down the line it could lead to breaking the driveshaft. anyhow, yes, lubing the hell out of it helps, but doesnt fix the problem, though it may seem to for awhile. apparently adding eaither new leafs or doing a AAL can dramitcally help the situation or even using traction bars. the thing with the leafs, going from 3 to 4, is apparently there has been a rather large complaint about the 3 leaf system sorta giving out, weakening a whole hell of alot. So im guessing toyota is doing the 4 leaf thing to help counteract the situation. I'm personally going to try the AAL and see how things work out with my axle wrap problem.
did the ad a leafe and problem gone i live in the northeast where its cold now (the grease thickens up) but no problem yet . has been three weeks and nothing...bump all gone
daniel
ny
94 Caravan 4-speed transmission bump when it rains vgb14 Caravan | Voyager 1 09-11-2009 01:19 PM
1997 Transmission Bump GTS767 Camry/Camry Hybrid/Vista 5 08-23-2007 04:36 PM
Rear end bump after stopping striker6 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 10-12-2006 08:26 PM
2001 tacoma transmission bumping. Lurkin42 Tacoma 7 12-25-2004 08:11 PM
2003 Gr Cherokee transmission slipping in stop and go traffic? xtroll Grand Cherokee | Grand Cherokee SRT8 12 10-30-2004 02:14 PM
