| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Engine Size and Cubic inch
Use a graduated cylinder, that way you can accurately measure your combustion chambers when you CC your cylinder heads!
You can increase bore and stroke to obtain more cubic inches. Within reason - most blocks won't tolerate a serious overbore, and stroking much beyond 3/48" (stroke on Chevy SB 267/305/350) requires modification to the block and rods.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
#17
3/48"? Try to find a ruler with that marking on it. Try 1/16". LOL
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
#18
#20
The displacement of the engine can't be changed by aftermarket parts. (at least not "bolt-on parts" THe engine would have to be torn down to add real displacement. However, the effective volumetric efficiency can be changed. In effect the engine "think"s it's bigger. Different heads or piston can increase the compression ratio this can allow more air/fuel to enter the engine making more HP. Turbos or Superchargers can be added they do the same thing. Even Nirtrous Oxide (NO2) can be added with provides more O2 that can be mixed with fuel to increase the capabilty of the engine. In all of these cases, the engine "thinks" it bigger, but it still has the same displacement.
