Old 11-30-2010, 03:46 PM
old_master's Avatar
Advisor/Moderator
Re: 96 gmc jimmy 4dr 4x4 cold start throttle down
I understand, I was just making it clear in the thread so everyone is aware of the possibiity of destroying the regulator, and how to avoid it.
You have to know how it works,
to figure out why it doesn't.
Old 12-03-2010, 12:37 PM
stealthprey stealthprey is offline
well it is up and running. Fuel pressure regulator helped it keep above 55lbs of pressure for at least 7 mins. The main reason it would not start and stay running is totally different however. Not something u would think it would be. There was a leak in the heater core hose on the water pump that leaks a little not a lot. But enough that if it sits for more than a couple days it leaked below the coolant temp sensor reading level. It was enough to start it but not keep it running. Once I topped off the coolant squeezed the upper hose to push some coolant back it fired right up and stayed running. Has been perfect past couple days.
Thanks for all the help Guys appreciate all tech info.
Chris
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
99 GMC Jimmy Heat goes Hot Cold hot cold snowlover4u2005 Problem Diagnosis 7 03-20-2008 08:41 AM
99 GMC Jimmy Heat goes Hot Cold hot cold snowlover4u2005 Problem Diagnosis 1 03-19-2008 02:15 PM
NEEDING to buy oil pan for 95 jimmy 4dr 4x4 with the 4.3 thebeastjuggalo Classifieds 0 11-29-2007 10:44 PM
2000 Gmc Jimmy Quit And Won't Start SunShine100163 Jimmy 1 09-12-2006 03:41 AM
