Old 02-21-2011, 10:16 AM   #166
rx7king
rx7king's Avatar
Re: ARTA NSX 2005 - Tamiya - 1/24
Oh man that is sooo disappointing
rx7king is offline   Reply With Quote
Old 02-21-2011, 02:43 PM   #167
Macio4ever
Macio4ever's Avatar
Originally Posted by ales View Post
Daym...
Fingers crossed, you'll be able to repair it without too much effort.
Unfortunately body cannot be saved... CL184 has wrinkled and cut through 2K making deep rows and discolorations. So I will have to put some effort in it.
It is going to be long, long thread and I hope that you won't be bored. I am going to buy new decals and body and do it once again - this time even better.
Just a bit. I feel like a
Macio4ever
www.mgsf.pl
Macio4ever is offline   Reply With Quote
Old 02-21-2011, 05:54 PM   #168
jaykay640
Ouch....that hurts! What did you use? 2K-clear? What's CL184??
jaykay640 is offline   Reply With Quote
Old 02-22-2011, 01:53 AM   #169
Macio4ever
Macio4ever's Avatar
2k first layer, sanded and clearcoated with 1K Gunze CL184 (Super CLear). Probably 1k was thinned too much - it has wrinkled and cut 2K
Macio4ever
www.mgsf.pl
Old 02-22-2011, 02:10 AM   #170
bri g
oh no, that last pic was heartbreaking! I'm guessing you'll need to strip the whole body again?
bri g is offline   Reply With Quote
Old 02-22-2011, 02:31 AM   #171
CifeNet
CifeNet's Avatar
Excellent progress you are making! Superb!
It is unfortunate to see the paint trouble with the final coat, but knowing your skill, I have a feeling that you will be able to manager it just fine.
Keep up the good work and hope to see you recovering from this 100%!
-- CifeNet
CifeNet is offline   Reply With Quote
Old 02-22-2011, 03:22 AM   #172
LeeABC
LeeABC's Avatar
Bad luck; I'm sure you will get the result you want in the end and I will look forward to seeing it. Good luck!
Cheers,
Lee
LeeABC is offline   Reply With Quote
Old 02-22-2011, 06:39 AM   #173
Macio4ever
Macio4ever's Avatar
No, I will not strip body. I will use the fresh one and paint and decal it again. I want it to be perfect and better than old one.
Striping last too long and I glued with epoxy front headlights - it would get me even more troubles.
As some suggested to repair it - there is no chance to repair without sanding down to primer. The base color layer is dissolved in some places - so I will not get perfect results anyway.
Macio4ever
www.mgsf.pl
Old 02-22-2011, 07:07 AM   #174
gpz900ra7
gpz900ra7's Avatar
Such a shame to see all your hard work ruined like that,
I know its off little consolation now but never mix clear coats or paint types, but you know this now to your cost.
Stick with 2k and you'll be fine.
Good luck with the new shell that you get.
gpz900ra7.
MY 1:1 toy
gpz900ra7 is offline   Reply With Quote
Old 02-22-2011, 08:50 AM   #175
Macio4ever
Macio4ever's Avatar
Thank you for the hints.
However, I was aware that mixing is sometimes risky but I usually succeed in it. It was not the first time I used 1K over 2K but first time with such troubles.
Mixing paint types has some advantages - you may easily remove paint excess and save layer underneath i.e paint with enamel over acrylic.
I am pretty sure that I rushed too much as I wanted to be on time on the local Modeling Contest. Sanded 2K, too much thinner = disaster.
Macio4ever
www.mgsf.pl
Old 02-23-2011, 05:45 PM   #176
Vladamor
Vladamor's Avatar
Send a message via MSN to Vladamor
Wow... I really do too much kinds of mix, and never get this... The first and only time a get something like this was spraying Tamiya clear spray can over a Zakspeed Mecedes over the nude body only with decals applied...
GREETINGS
Vladamor is offline   Reply With Quote
Old 02-27-2011, 02:17 AM   #177
DerXL
DerXL's Avatar
What a shame.
I hope you have better luck with the new shell...
Axel
Visit my homepage for WIP's and galleries :
www.axelv.com
DerXL is offline   Reply With Quote
Old 02-27-2011, 12:26 PM   #178
Macio4ever
Macio4ever's Avatar
And the stroy begins...
Body is already sanded and almost ready for the primer. I changed order of the assembly - air intakes are glued first as well as head lights will be glued than painted. Will see - I belive that it will look bettter.
Rear wing is ready
Orange putty is Tamiya Light Curing Putty
Macio4ever
www.mgsf.pl
Old 03-01-2011, 03:45 PM   #179
rollin80s
oh man i just saw what happened. sucks it happened. but im glad to see this continue.
well, as always, ill be looking forward to more.
rollin80s is offline   Reply With Quote
Old 03-03-2011, 08:19 PM   #180
MidMazar
MidMazar's Avatar
Why did you fill the wing, are they sopposed to be farther apart? Good luck.
Moze teras nic niedobrego sie stanie.
In Progress
Tamiya 1/24 subaru impreza 2005 monte carlo - solberg audi_racing Completed Projects / Gallery 9 12-01-2008 08:49 AM
Arta Nsx 2005 karls0415 WIP - Motorsports 6 07-01-2008 01:34 AM
Honda NSX Mobil 1 - Tamiya 1/24 Macio4ever Completed Projects / Gallery 8 02-29-2008 10:59 AM
NSX Mobil 1 - Tamiya 1/24 Macio4ever WIP - Motorsports 83 02-26-2008 01:08 PM
Tamiya 1/24 Honda NSX - Completed PICS Captain Mark Completed Projects / Gallery 11 09-22-2005 09:25 PM
