Old 06-29-2002, 08:10 AM
kosmas kosmas is offline
Question Spark Plug Gapping....
Hello Everybody...
I wonder whether if somenone could really answer my question since it's very important and critical for me.
I own a Renault Megane 1.4l 16V
Recently i replaced my Champion RC87YCL spark plugs which were originally placed by factory with NGK BKR7EVX-11
The difference between them is that NGK are a 2 units colder than the Champion and the Champion's Gap is 0.8mm and NGK's 1.1mm
Since now engine is running better than before but i wonder...
Is there a possibility to cause any damage to the engine due to colder and due to 0.3mm gapping difference ?
Thanks for your answers..
Kosmas
Old 06-30-2002, 12:05 PM
sciguyjim sciguyjim is offline
Thumbs down
Two heat units colder sounds like a lot. Too much. I would expect the plugs to get carbon fouled, unless you do a lot of high speed driving for extended times. I do quite a bit of slow-ish driving around town and every time I've asked a shop if I should go to a higher heat range to burn off carbon they always say no. They say the mfgr suggested plugs are best for a wide range of driving conditions.
Also, the wider gap can be helping you now, but as your ignition system ages you can end up with a lot of misfiring if your system is no longer able to supply the high voltage needed for the wider gap.
Old 07-06-2002, 10:36 AM
Scanner Scanner is offline
You could go to a higher output coil, but that may cause arching in the cap, the ign. system was not designed for HEI type ign.
Remember, electricity, follows the path of least resistance.
spark plugs freakyfire05 ZX2 2 02-17-2009 12:03 PM
spark plug gapping for NGK iridium plug MillyVanilly Millenia/Xedos 9 2 09-27-2004 09:45 AM
spark plug gap igo4bmx '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-11-2002 10:47 PM
Spark plug gap with performance Nizmolee Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 11-06-2001 06:30 PM
