Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 03-28-2002, 08:33 PM
hermunn123's Avatar
hermunn123 hermunn123 is offline
Send a message via AIM to hermunn123
reliability of a 93ish 300ZX Turbo
how reliable are early '90 models? how long do they last? what problems do most encounter? etc...
thanks!
Please impede from anathematizing me just because I elocute loquacious locutions more Brobdingnaging than one could elucidate with a perspicacity as Lilliputian as your own.
Old 03-28-2002, 08:52 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
This depends on who drove it, how s/he drove it, how s/he took care of it if at all, what kind of products/fluids did they use...etc.
Here's some tips from Shawn at www.twinturbo.net
First off body:
The dealers first off will pressure you, screw that. If the car is on the lot go back when they aren't there, maybe a Sunday this way you can check it out without anyone there. If something is wrong they will keep you busy so you don't notice it. These were 40-50k dollar cars so if any got wrecked you know for sure shops tried to salvage them & they are back in the market.
Signs of paintwork besides obvious mismatching:
1. Lift up any rubber seals on the car even around the windows & look for a paint edge.
2. Check every wheel well & even see if you can lift up the edge of the liner to see if there is a paint edge.
3. Pop the hood & hatch. Check the bolts that hold the quarter panel on, should be covered with factory paint & look like it's never been removed, if it's been
removed you will know it because it's near impossible to line it back up & not show where bolt location was previously.
4. Check the gaps on both sides of hood, should be small & equal. Check the gaps right under door where fender meets door, make sure same on both sides.
Check gaps on both sides of bumpers front & back.
5. Open doors & look through hinge ares for messed up sheet metal on the pillar.
6. Check in back upper hatch seal area for signs of wreck.
7. Always look in the spare tire well.
8. Look for OEM glass & always check for cracked windshield this is easy to miss & not uncommon.
9. Look up under the bumper at the frame that connects to it, look under hood area at that also, this is what gets straightened from a head on collision.
10. Whatever you do NEVER & I mean NEVER buy a car at night! Even if you go where lights are. In the day look down the body for dings & depressions especially since Zs are durasteel.
11. I don't use a magnet since I can generally knock & tell if has bondo but feel free. Owners will look at you funny & get irate sometimes...hey, if they don't like it, don't buy it, this is NOT a small investment. If the owner knows the car is excellent they will have no problem whatsoever letting you check it up & down, normally they are pretty proud when it's really clean.
12. I prefer stock paint that has been maintained.
13. Check the calipers, see if they look all the same.
14. Check lights for condensation..though sometimes this is not indicative or wreck, check the seal area & alignment around the lights very hard to get to factory spec.
I almost bought a Supra (but decided against it) at a Toyota dealer until I checked the hood & noticed huh....the gap isn't even. Then I checked up
under the wheel wells & counted the bolts, guess what? driver fender missing 3, then checked top bolts on 1/4, saw where bolts had been removed...I bailed..made me to nervous. Keep in mind this might be sometimes nessary for autowork so not it's always a negative.
With individuals just ask them, ever been in an accident, alot of times they will tell you! Or they might say a little fenderbender on bumber but Nissan fixed it. I called a lady on a Z & outright asked "ever been in accident" she said Nissan told her car had been repainted. *wow* all I did was ask. =)
Interior & Electrical:
1. Pretty obvious but check the leather for paint, dealers like to spray messed up leather with leather paint.
2. Being these cars are T-tops check the seat rails for excessive signs of corrosion from where they fell asleep & a rainstorm hit while they were inside. =)
3. Check the radio, easy to talk down dealer a little because I gaurentee the stock system has problems.
4. Work everything electrical on the passenger side. Duh, I always forget this...never know when a seat or window switch won't work over there.
Too many factors with engines, read the faqs & take to a shop...but whatever, test drive a friend's then the one you want, not down the street, get it on the interstate, work the gears & *listen*. Drive it for more than 25 minutes when you get serious (overheating, etc) , I never like to waste the owners time so I go look, come home, think & cool down my jets, then if thats the one I want tell them I'm serious but want to drive it for awhile.
Other tips:
Now other things I've found with dealers is 9 times out of 10 they bought the car at auction, if the car is 22 they paid 18 or less. Believe me, 2 grand off the asking is a given, unless it's unusually low priced. Know the value in kbb/edmunds/& general area. I just bought this 94 convertible at a local nissan. On the lot for $22.7K & this baby is mint. Book is $22.6K I got it under 20. Now if your credit is poor, it's much tougher since they have the advantage. Individuals are much tougher to talk down but if the add says best offer that is dead givaway they need to sell it bad...payments or something, so offer less. If the car is mint the owner will generally not budge for good reason & I have no problem paying more for mint.
By far the cleanest Z's Ive seen are at Nissan dealers. Cleanest I've ever seen are at Ft Lauderdale Nissan but they price accordingly. I've talked to the Zman down there & he sounds impressive.
Last but not least! Carfax! but don't be surprised if you see auctions...that is normal part of auto business but I double check when I see that. Auto auctions are VERY good at cleaning cars for the sellers, they can hide anything.
Yours truly,
Gabriel
1991 300zx Twin Turbo Beast. Help? Over500horses 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 2 05-15-2012 03:45 AM
Z31 300zx Turbo vs 89-92 Supra Turbo flip888 Car Comparisons 5 10-17-2006 05:29 PM
260z swap. 280zx turbo/300zx turbo/skyline gtr Wide260 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 8 11-11-2004 11:43 PM
More Reliable, NA or Turbo? NSXN8 MR2/MR-S 3 05-11-2003 10:19 PM
300zx Convertible to 300zx turbo? Bong_the_Monkey Car Modeling 6 08-19-2002 11:50 PM
