Old 12-28-2003, 06:27 PM   #1
T!mmy
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Angry Installed short shifter...problems!
Ok I installed a short shifter and now it seems like going into gears is harder. It's like you have to push that much harder to get it into a gear.
ANy help?
thanks in advance
Brian
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
T!mmy is offline   Reply With Quote
Old 12-28-2003, 07:53 PM   #2
pisetup
pisetup's Avatar
Send a message via AIM to pisetup
Re: Installed short shifter...problems!
Are you using aftermarket bushings?
- joe
pisetup is offline   Reply With Quote
Old 12-28-2003, 08:31 PM   #3
T!mmy
no...
Old 12-28-2003, 09:14 PM   #4
99civic03
99civic03's Avatar
Send a message via AIM to 99civic03
You NEED bushings! It will make shifting 1000x smoother, get some!
99civic03 is offline   Reply With Quote
Old 12-28-2003, 09:35 PM   #5
T!mmy
Where is a place that has good ones?
thanks
Old 12-28-2003, 09:37 PM   #6
pisetup
pisetup's Avatar
eBay - Neuspeed bushings
- joe
Old 12-28-2003, 09:44 PM   #7
T!mmy
Old 12-28-2003, 09:48 PM   #8
T!mmy
liek that?
Old 12-28-2003, 10:31 PM   #9
T!mmy
ok I went to the car to try and describe how it is better...whenever I push the shift lever forward it seems like something is too tight. It's just harder than it should be...it goes into gear fine it just feels tight. What do ya'll think?
Old 12-28-2003, 10:44 PM   #10
BullShifter
BullShifter's Avatar
Re: Re: Installed short shifter...problems!
Did you follow the install directions?
You have have over tightened, not greased, forgot a piece. Go back & check your work.
Summit Racing has the stabilizer bushings for $10(energy suspension) they should be used with a short shifter, but won't solve your issue.
Which shifter is it?
BullShifter is offline   Reply With Quote
Old 12-28-2003, 10:53 PM   #11
T!mmy
I didn't have instructions...I bought it from Kicker1_solo...do you have a set of standard instructinos on how much to tighten them?
Old 12-28-2003, 10:57 PM   #12
BullShifter
Old 12-28-2003, 11:04 PM   #13
T!mmy
yea that's the one I followed but it doesn't tell me how much to tighten the bolt that the actual shift lever connects to
don't know if thats the right lingo but by shift lever I mean the part the knob connects to
thanks
Old 12-28-2003, 11:07 PM   #14
T!mmy
ahh I see it...it says 16lb ft
Old 12-30-2003, 04:54 PM   #15
T!mmy
k one more question about my install it's rubbing the top of my exhaust and I was going to just bend it down but since it was on the rubber hangars and all that it gave. How should I go about stopping the rubbing or bending the pipe/heatshield? C'mon Ricochet help me out lol thanks
Installing Short Shifter In 92 Honda Civic HONDA_TEC How-To's and Walk-Through's 2 01-24-2006 12:47 AM
how to install short shifter? Civic_D16Y5 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 06-26-2004 03:57 AM
install short shifter 4g4d_getone '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-12-2003 12:58 PM
installing short shifters esko1269 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 11-21-2002 06:36 PM
