Old 08-27-2003, 10:52 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
timing belt
i have a 90 civic d15 block but with a 95 d16z6 vtec head, n i need to put a timing belt on to finish the swap, now the prob is do i get a 90 belt or a 95 belt?
Old 09-02-2003, 11:46 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
search the part number for the two engines, I think they probably have the same part number, may be 1 number off (but I believe they are the same).
The best way is to go to the part store and compare the two belts (length and width) and see if they are the same.
Another thing to pay attention is to check for the "teeth" of the belt to see if it will match the gears. M
ake sure you install the belt correctly, cause if you skip a "teeth" on the cam gear, it will make 11-12 degree off the cam timing.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 09-03-2003, 01:38 AM
think ill try that thanks....let u know if they r the same or not....
Old 09-03-2003, 04:29 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
get the 95 belt.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 09:51 PM
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 03:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 01:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 04:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 05:30 AM
