Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 07-07-2003, 09:38 PM   #1
Ruhvngfun
Front suspension popping noise
Hi,
My front suspension on my '97 Jimmy 4wd SLT makes a slight popping noise almost as if it's "sticky". This noise goes away when it's raining and gets wet. I've recently had it in shop a couple times for front end work yet this slight popping noise persists. Any ideas are greatly appreciated.
Ruhvngfun is offline
Old 07-13-2003, 10:42 PM   #2
dracer398
dracer398's Avatar
Send a message via AIM to dracer398 Send a message via Yahoo to dracer398
When does the popping noise happen? Also How many miles are on your Jimmy? The ball joints can make a klunking noise but you mentioned that you took it to an alignment shop so you have to think that they checked those. But it's pretty easy to check the upper ball joints. All you have to do is jack up each side one at a time under the lower control arm, when the tire comes off the ground approx. 2" grab the top and the bottom of the tire and push the top and pull the bottom then pull the bottom and push the top. If you have any play in the joints You should change them.
Good Luck!
dracer398 is offline
Front end popping noise during turns tosc1077 Avalanche 13 09-11-2008 08:41 AM
Front suspension pop kahjdh Silverado 4 04-05-2008 04:32 PM
Front suspension popping barkboy6 Mustang Talk 0 01-23-2006 06:07 PM
Front End Popping noise when going over bumps BlazerLT Blazer 21 10-24-2004 02:03 AM
Front end popping noise. Michael R. Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 08-25-2003 06:27 PM
Closed Thread
