Old 04-04-2008, 09:01 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Front suspension pop
So after I have looked through the forum I found 2 possable problem areas,
1: The ball joints are bad;
I replaced all 4, didnt help
2: Intermediate shaft worn,
My truck is an 01 4x4 and i dont have a rack+pinion but the gear and relay rod set-up. Is the intermediate shaft problem only on the rack and pinion or all?
3: also how much does the nickel plated yoke run?
For some reason all of this started happening within the last month and is really irratating.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 04-04-2008, 09:24 PM
bigbadram51 bigbadram51 is offline
Re: Front suspension pop
Have you checked your wheel bearings/hub assembly
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 04-05-2008, 08:54 AM
kahjdh's Avatar
Lifted the truck anf there was not play up/down or side/side. When I had the knuckles off when I did the ball joints they looked alright.
Current Cars:
Past Cars:
Old 04-05-2008, 10:16 AM
A couple years ago, I had an awful rubbing/grinding sound. Granted mine wasnt popping, so I did the normal check for bad wheel bearings, nothing, but when I spun it....ssscrape and some small little pops...replaced it, all kinds of quiet. The unit hubs are notorious for being weak in these trucks, thats why I thought it was the hubs. Have you checked, tie rod ends all the way up to the idler/pitman arm for play.
3" PA Body Lift
Covermaster Top
Old 04-05-2008, 03:32 PM
kahjdh's Avatar
Bought new tie rod ends and im going to put those on next week, as for the bearing im still kind of holding off b/c of the $300 price tag for both sides.
Current Cars:
Past Cars:
