Old 05-05-2011, 08:52 AM
philrmech philrmech is offline
96 chev ac does not blow hard
I have a 96 chev pu and the air does not come out of ac vents.The air is blowing and it comes our on def and in the floor in that mode but not out of ac vents. help thanks philrmech
Old 05-05-2011, 09:08 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 96 chev ac does not blow hard
Check your mode door actuator, behind driver's side knee bolster on left side of HVAC housing-- you must lay on your back and use a flashilght to see it.
See if it is moving, not binding, if all armas are connected, not flopping around.
Lat on I did had a plastic Walmart bag sucked up into recirc door- but his complaint was blows good until you hit recirc button.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-07-2011, 06:39 PM
autotech234 autotech234 is offline
very common problem you bend door is control by vacuum and when it looses vacuume it defalts to defrost. Under the hood on the passager side there will be a small plasic vac line coming throw fire wall going to the top of the engine manifold, follow that vac line and check for leaks if it is leaking repair them and that will fix your problem
heat or ac does not blow out like it should wrkmn84 Camaro Discussions 1 11-27-2004 07:19 PM
88 Cherokee heater fan does not blow. 88Jeepster Cherokee 3 11-09-2004 11:16 AM
She does not blow... GMez12 Cherokee 3 07-16-2004 04:41 PM
Vent lo-hi does not blow RochelleC S-10 3 04-20-2004 05:18 AM
92 grand am heat does not blow out strong jfreeway83 Grand AM 7 02-14-2004 02:31 PM
