Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 02-22-2011, 11:31 PM   #1
FORDGUY09
FORDGUY09's Avatar
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
97 transport problems
got a 97 transport in and having issues trying to get it to start got fuel pressure (45 psi ish), got spark, engine cranks but no fire please peeps give me ideas to look at.
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
FORDGUY09 is offline   Reply With Quote
Old 02-23-2011, 12:22 AM   #2
LMP
LMP's Avatar
Re: 97 transport problems
I'm not sure of the logic with the 3.4 setup as 3x and 24x are sent by separate sensors contrary to my 3.8. anyway I would verify presence of electric pulses to the injectors.
the 3x signal from front crank sensor is sent to the ignition module (ignitor) and used in the ignition module itself to fire the coils (so you do have spark) but then forwarded to the computer through a buffer circuit part of the ignition module. IN my case the buffer was shot and the 3x signal was not fed to the computer and no firing of injectors occured. A new ignition module solved the problem.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
The Following User Says Thank You to LMP For This Useful Post:
FORDGUY09 (02-23-2011)
Old 02-23-2011, 01:08 AM   #3
FORDGUY09
FORDGUY09's Avatar
how would you go about checking the injectors with out taking off the intake manifold plenuem? btw here is a little more info: the people they bought the van from said that when they was driving it home one day it just died and they coasted it of to the shoulder and it stared right up drove for 30 mins and then it did it again, they got it to start back up again and it drove home the rest of the way
1997 Honda Accord
2016 jeep patriot
Old 02-23-2011, 08:39 AM   #4
LMP
LMP's Avatar
YOu disconnect the wiring to an injector and connect an oscilloscope, or voltmeter or a small 12v light bulb instread. Pulses will show as a short burst of voltage or light. I think the 3.4 injectors are well hidden and in this case if impossible to reach easily, the connectin to the wiring can be taken upstream on the wiing. A voltmeter test does not need that the injector be disconnected if you can connect in some way to the wiring.
ANy check engine codes ?
Old 03-04-2011, 03:42 AM   #5
FORDGUY09
FORDGUY09's Avatar
no engine codes that i can get. i have been told maybe the comp went out but not sure.
the previous owner said " We where driving down the road and it just died, so we pulled over, put it in park and it started right back up. We drove for about 30mins or so and it did it again so we pulled over and it started right back up but we made it home and it dies again"
i did not see any where up the wire loom any where to check the fuel injector pulse but do know that the upper intake manifold covers all the injectors to where you cant check them at all. i know i got 45 psi fuel and have good spark all the way across the board just dont know where else to go from here is all
1997 Honda Accord
2016 jeep patriot
Another 3.8/95 transport problem. canaris Trans Sport 3 08-22-2006 09:00 AM
95 Transport problems with two rebuilt trannys Turboready Trans Sport 2 06-22-2006 09:23 AM
1996 transport problem codes chris96transport Trans Sport 4 05-31-2006 09:46 PM
HELP!!! 94 Transport problems TwistidOne Trans Sport 6 12-22-2005 04:45 PM
1995 Transport Problems carrigan Trans Sport 8 10-25-2004 04:41 PM
