Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 11-25-2010, 11:42 PM   #1
Applianguy
tc lockup still troubling
My 95 4x4 blazer 4.3L is locking unlocking tc repeats at 45 - 50 mph. The voltage is coming from PCM and dropping off. I have replaced all sensors, the trans fluid is fresh and clean. 90+ of my driving is around town. Can I just leave the tc lockup off?? I have a large fan trans cooler with an electric fan so heat is not a problem????
Thanks Mike
Applianguy is offline   Reply With Quote
Old 11-26-2010, 12:38 AM   #2
viggy58
Re: tc lockup still troubling
by "all sensors" which ones did you replace?
i would assume that the speed sensor or bad PCM would cause the signal drop, but i'm def not a trans expert. (esp since my blazer is a 5 speed 2wd)
do you have the option to keep it out of overdrive?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
viggy58 is offline   Reply With Quote
Old 11-26-2010, 01:22 AM   #3
Applianguy
I replaced the TPS, Map, air temp sensor, clean egr. Engine runs great.
Old 11-28-2010, 07:58 PM   #4
Schrade
If the front tires are wearing unevenly, they will cause a problem with the TCC - read it in the FSM. Put the 2 rear tires in front.
Schrade is offline   Reply With Quote
Old 11-28-2010, 08:09 PM   #5
Applianguy
The front were nice and evenly bald so I have 4 new 235/75/r15 on it for a week now. If I'm driving under 40 or over 60 all is good.
Mike
still trouble....92 sentra roonie Sentra | 200SX (USDM FWD) 1 04-17-2007 07:08 PM
still trouble....92 sentra roonie Sentra | 200SX (USDM FWD) 0 04-16-2007 07:46 PM
Trouble with '89 Cherokee Trouble Codes... citizen@large Cherokee 2 08-04-2006 01:10 PM
still trouble with front halfshafts marklar88 Celica 3 10-14-2005 05:52 PM
still trouble starting ryanb4614 Blazer 7 08-25-2005 08:07 PM
