Old 08-23-2005, 10:23 AM
ryanb4614 ryanb4614 is offline
Send a message via AIM to ryanb4614
still trouble starting
Trouble starting 1997 chevy blazer 2 door 105,000 miles
Replaced:
Battery
Fuel filter
Starter
Rotor and cap
Spark Plugs
Cat
Running out of ideas
I turn the key to start it, the engine just cranks takes about 3 tries then starts and once it is started runs good, doesn't stall at all thats why it doesnt sound that it is the fuel pump. I brought it to a friend he said that my motor mounts are bad and my y pipe needs to be tighten.
My y pipe was smashed in the middle so i cut it and put a flex pipe on it with u mounts. Seems like its holding up.
I'm going to bring it to a garge i want to give him ideas of what to looks at so he isnt replacing things that doesnt need to be replaced and charging me i am trying to get rid of the car.
Old 08-23-2005, 11:30 AM
mullinsmedic mullinsmedic is offline
might want to replace the ignition switch.
Old 08-23-2005, 03:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: still trouble starting
check fuel pressure.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-24-2005, 10:49 AM
the guy i am bringing it to said that it most likly the fuel pump he replaced 3 of the on blazers in the past year. he said it would cost $200 from what i see that seems like a good price. Then i could finally get rid of it. Since winter is coming what do u think is a good asking price:
I bought it for $5800 with 98000 miles
1997 chevy blazer LS 2 door 4x4 good condition
105,000 miles now
new battery
new start
ect.
new stero system
what you think is a good asking price
Old 08-24-2005, 09:55 PM
The guy called me and took a look at it tonite he said it deff is the fuel pump but tomarrow he is going to see if there is anything he could do to fix it with out buying a new fuel pump..... How much does the job cost to get a new fuel pump in....
Old 08-25-2005, 11:27 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
At least 2 hours labor, could be 3 or 4 hours. You need to remove the tank to get at the pump. The pump assembly is a minimum $325.00 for
a Carter assembly, over $500.00 from a Chevy parts counter for an A.C.Delco assembly. The pump alone is only available from Chevy, costs about $200.00, but you're better off with the whole assembly. Don't forget to get new gas line clips , one 3/8" and one 5/16" for the feed and return lines. Using the old clips can cause leaks where they attach at the pump assembly.
Old 08-25-2005, 03:26 PM
cars fixed $475.00 pump, regulator, sending unit fixed cost me free, parents paid
Old 08-25-2005, 07:07 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
105,000 miles now
new battery
new start
ect.
new stero system
I just paid $4300 for my 97 blazer LT 4 door 4x4 in good condition with 109,000. I'd probably pay a little less for the 2 door LS model.
I can wear a blazer. I can drive a blazer.
