Old 12-29-2002, 01:47 PM   #1
jivaro
Angry 2002 Olds Bravada Remote
My 2002 Olds Bravada remote stopped working and I replaced the battery which did not help. I went to the dealer and he reprogrammed the remote and it works fine. Now, my wife's remote does not work. I would like to reprogram her remote but really do not want to travel back to the dealer. Does anyone have the sequence of steps necessary to reprogram the remote? The technician that reprogrammed my remote had a sheet with the sequence necessary. Perhaps someone might be able to help. Thank you. :smoka:
jivaro is offline   Reply With Quote
Old 12-30-2002, 09:14 AM   #2
Shortbus
Blah blah blah
Send a message via AIM to Shortbus
Here is the programming instructions.
Transmitter Programming
Important
All transmitters which are to be recognized by the Liftgate Module (LGM) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
You may program up to 4 transmitters, using either of the 2 following procedures:
Method 1 - No Tools Required
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Method 2 - Scan Tool Required
Install a scan tool.
Turn the ignition ON, with the engine OFF.
Use the scan tool in order to access the Lift Gate Module (LGM) Special Function: Program Key Fobs menu.
Follow the directions on the scan tool in order to program the transmitters.
© Copyright General Motors Corporation. All Rights Reserved.
Document ID # 665615
2002 Oldsmobile Bravada
Shortbus is offline   Reply With Quote
Old 12-30-2002, 09:56 AM   #3
jivaro
Thumbs up
Thank you very much for the help. They both work fine now. Obviously the two remotes must be programmed at the same time, which the dealer is not aware of. Next time I stop by the dealer I will have to inform him of the procedure.:hehe: Thanks again.
2002 Buick Regal remote control door lock receiver brytheisen Regal 2 07-20-2010 12:07 PM
96 bravada shifter issue nassaudaddy53 Problem Diagnosis 0 07-17-2010 11:09 AM
02 Bravada Smart Track fails: no AWD RM02 Bravada 2 07-22-2009 01:45 PM
2002 Olds Bravada njyahoo Bravada 2 11-22-2004 04:33 AM
programming keyless remote for 1993 Olds Bravada fergus General Discussion 1 11-08-2002 09:03 PM
