Old 02-05-2003, 09:41 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Sqeaking New Brakes and Whistling CAI, How do I fix?
Title explains it pretty much, I got new EBC Rotors/Pads about 3 weeks/500 miles ago, and just recently they started to squeak, and since i no nothing about brakes (except how to install them now) I dont know how to stop the squeaking. Also, my AEM CAI starts whistlin at like 3k rpm, never did it in my old car, does the whistlin mean its not gettin enough air or wat? All info greatly appreciated, thanx.
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 02-05-2003, 09:50 PM
york2600 york2600 is offline
Send a message via AIM to york2600
I'm not sure if this helps, but I have a really bad whistle that I thought was my intake. It happens when I accelerate and goes from about 2k to 4k. While I was doing some work on the car I took it for a spin around the block without the CAI on and it was still whistling. I never did track it down, but you may want to see if it whistles when the intake is removed.
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 02-05-2003, 11:12 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
My friends teg CAI whistles, don't know what causes it, he just figures its the filter, or its supposed to make that sound, i keep telling him its not andhe just disagrees.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-06-2003, 06:52 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
My civic whistles when i boot it too... dont think its anything serious
Old 02-06-2003, 09:01 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
intakes just make the sound themseleves its nothing to worry about.
as far as the brakes, did you put the anti-squek goo on the back of the pads before you installed them? if you did, then you just got alot of brakedust between them and the rotor, due to hard braking.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-06-2003, 09:10 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Whistle noise could also be a vacumn leak...but intakes do tend to make a whistle noise too.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-06-2003, 10:48 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
so you are discounting the fact that it may be something other than the intake in branman's case also?
Although it probably is nothing to worry about.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 02-06-2003, 11:31 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
The squeaking noise means u probably have a leak somewhere in the intake. Check your adapters and check the hose thats connected to the intake.
Old 02-06-2003, 11:32 AM
mellowboy's Avatar
With his set up they don't create brake dust. Anyways try using what he suggested.
Old 02-06-2003, 11:41 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
try carb cleaner on the disk pads to get of the crap on em that should get rid of the squeek
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 02-06-2003, 12:10 PM
darolh darolh is offline
The whistle form you CAI is normal. Honda went to great pains for the stock system to be quiet. That' why the resonator box and all the goofy shaping of the factory inlet.
The CAI manufacturers don't care about this. My AEM squeals like a pig too.
DO NOT SPRAY CARB CLEANER ON YOUR BRAKES!!! The safe bet is to use only brake cleaner.
EBC told me to not use goo or shims. I didn't. They don't squeal.
If you pop the pads out and scuff the surface good on a piece of sandpaper laid on a flat surface you may kill the squeal. Reassemble per EBC's instruction.
Old 02-06-2003, 02:47 PM
crxlvr's Avatar
only use brake cleaner on your brakes, the other stuff could damage the friction material on the pads.
and yes you could have a vacuum leak also but he would have seen other problems as well, so i told him the sound is most likely normal.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-06-2003, 04:40 PM
Thanx, Wat about these probs.......
Thanx everyone for all the help, I was really just making sure neither was serious, and it doesnt sound like it is, but Ill email AEM about the whistlin just in case. As for brakes, when i got a few hours Ill take em out and sand em, until then, ill just live with the squeaking. Here's another prob, not sure if its serious, but better safe then sorry. Occasionally, when its cold out, and i try to start my car and it turnover and starts, but once i let the key back to its regular position, the idle drops and the car turns off, it doesnt stall tho, cuz it never actually jumps or anything, just turns off (and buy off i mean just the engine, the radio and lights still work). If anyone knows wat could be causing this plz lemme know. Thanx again all.
PS This is gonna sound real dumb, but wat all is involved in a tune up besides spark plugs, wires, and changin the oil? The reason I ask is that my car hasn't had a tune up in a long while i believe, so tomorrow im gonnna buy all the stuff, cuz my car gets kinda sucky gas mileage (only 22 mpg, and thats mostly highway!) so I'm hoping a tune up helps a little. Thanx, again again.
-BMan original
Old 02-06-2003, 04:45 PM
mellowboy's Avatar
Re: Thanx, Wat about these probs.......
Yeh its normal. My car does that also but when i did it the second time its all good. What oil weight are you using? 5w or 10w?
Old 02-06-2003, 09:32 PM
VWRacer VWRacer is offline
tune up= plugs, wires, ditributor cap, rotor, air filter
New Brake Pads Grinding Rotors HELP williamjay199 Taurus | Taurus Wagon 1 07-13-2009 12:51 PM
New brakes and Front Bearings $1000???? FrugalMonk01 Rodeo | Passport | MU 8 01-13-2009 10:48 PM
Brake Problems-New Brakes and Rotors justinWants2know Jetta/Vento/Bora 1 07-27-2005 08:27 PM
knocking and whistling after fixing fordperson Taurus | Taurus Wagon 1 01-12-2005 02:57 AM
New brakes in front sqeaking. Jeff R LeSabre 1 04-02-2004 01:22 AM
