Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-26-2008, 02:20 PM
FrugalMonk01 FrugalMonk01 is offline
New brakes and Front Bearings $1000????
I have been quoted $1000 for new brakes and both front wheel bearings by Monro. This clearly does not sound right but i feel as tho i must pay because the front right wheel vibrates violently when turning. I have been quoted by the mechanic that fixes passports in our area 650 just to do the front bearings, so with brakes it would be about the same if not more. HELP!!!!!! I dont have this kinda money, and DIY is not an option! Again HELP! Im in CT if that matters.
Old 12-26-2008, 02:22 PM
Re: New brakes and Front Bearings $1000????
Its a 2000 passport. Forgot to mention it earlier.
Old 12-26-2008, 04:48 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
A grand is way too much. Doing the brakes at the same time should only add the cost of the parts since you basicly do a brake job anyway to replace the bearings. Pads shouldnt be more then about $60 for good ones. Dont know if they plan to just turn the rotors or replace them.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-26-2008, 06:11 PM
amigo-2k amigo-2k is offline
Isuzu Guy
My dealer charges, 100 to repack the front wheel bearings on a 2wd and 180 on a 4wd. I would assume it is the same thing in your case accept you are paying for new bearings too.
Brakes up front would be 180 installed (OEM parts; just the pads) at my dealer.
No clue as to what the bearings cost. So 650 probably isn't to far out of line.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-26-2008, 10:51 PM
Ramblin Fever Ramblin Fever is offline
Are they talking wheel bearings or ball-joints? Ball-joints yes, are very expensive to have someone else do.
Wheel bearings and brakes shouldn't be nearly that much, shop around.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-27-2008, 09:51 AM
660Ryder 660Ryder is offline
I'm not sure where you are in CT, but a local shop I could recommend is in Bristol, CT. They have done a lot of work for my family's vehicles at reasonable rates. (I don't work there or anything, but it would be a good place to get a quote from.)
Digiovannis Auto Service
448 Park St.
Bristol, CT
860-584-0832
Old 01-07-2009, 11:10 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
$1000 sounds a little high to me too, but what everyone has failed to mention so far is the bearing races. If they are replacing the races too (and they should be to do it right), there is a good bit of labor involved to R&R the races.
You should be able to get an itemized estimate so you know everthing they want to do and how much it costs, parts AND labor.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-10-2009, 01:10 PM
Festivus's Avatar
Festivus Festivus is offline
I did this myself when I had to replace my front rotors a couple of years back. It's a big job. I'm no expert but not a novice either. It took me about 5 hours work to do it. I didn't get a quote from a shop.
Old 01-13-2009, 09:48 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
It's not a difficult job just very time consuming. You can probably do the entire job for under $300 at home. Of course that all depends on the brand of pads, rotors, and etc.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
