Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 07-26-2005, 10:08 PM
justinWants2know justinWants2know is offline
Send a message via ICQ to justinWants2know Send a message via AIM to justinWants2know
Brake Problems-New Brakes and Rotors
Simple Question....The four lug nuts on My 98 Jetta GLS hold the rotor in place...correct? Well They grind really bad and i was thinking the set screw on the rotor would have something to do with it grinding..they are both broke off....Hmmm
Old 07-27-2005, 07:27 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
THe bolt usually breaks off when you remove the old one... big deal, sand down the stub if there is any sticking out and put the new rotor on over it. As long as your wheels are torqued on all the way they shouldnt grind. If they do, then theres something alse wrong.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
