Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-18-2002, 02:04 AM
95gsrdavid 95gsrdavid is offline
Exclamation Problems with nose coming from engine
ok heres the thing i had to replace the cluth master and slave cynider fuilds are find...i bled everything...but get this it makes this nasty ass sound even when not in gear...after i replace the master cynider it got easier to shift but it still is hard...not how it should be...ok let me start over i chance the cluth out first still didn't acted right so i found the slave was bad changed it then it worked great shifted perfect(only drove it like 20mins) then out of nowhere it wouldn't go into gear at all had to force it but i just cut it off and but put it in first had this nasty noise...shifting was hard as hell got it home check fluids tranny was low drained it and filled it up still wouldn't shift in gear... i took the tranny back out everything looked good new cluth new slave then i found out then slave goes usely master is out to so did that and now it's the same nasty sound even when not in gear it like a deep loud ticking type sound...also the fly wheel was turned... i've ran out of ideas here. only thing it could be now is tranny.!!!! right?...what do ya think?>
Old 05-18-2002, 11:26 AM
HonDork HonDork is offline
Send a message via AIM to HonDork
It could be the pilot bearing in your tranmisson. If it makes a noise when the clutch is out, but not when it is pushed in then I am pretty sure that could be it. I had that problem with my Civic. It made a loud grinding noise and sounded like poop
meep meep!
1990 Runner with Noise coming from front krc333 4Runner/GX470 16 12-10-2005 06:53 AM
vibration coming from engine krebulon '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 09-18-2003 12:49 AM
weird clicking noise coming from engine... azazel61 General 8 08-23-2003 11:04 PM
dull noise coming from engine.... dek Engineering/ Technical 7 10-17-2002 11:41 PM
Weird ass noise coming from engine Edho2002 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 08-15-2002 05:03 PM
