Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 06-11-2002, 03:03 PM
rfranklin rfranklin is offline
88 325e overheating
When I'm driving on the open Highway the temperature is find but the temperature gauge
can go pass the 3/4 mark when I'm in stop and go traffic. In April 02 I replace my Timing
belt and water pump then shortly after that the car began to overheat. In May I replace 4
coolant hoses but no luck so I replace the thermostat and the thermostat housing still no
luck.Last week I replace the Clutch Fan and guess what no change the Radiator is less than 4
years old and I'm sure that's not it. Do anyone have any suggestion on what I should try
next before I go mad.
Old 06-13-2002, 04:58 AM
ryans_325 ryans_325 is offline
Send a message via Yahoo to ryans_325
try replacing the gauge
Old 06-14-2002, 01:22 AM
Accordean Accordean is offline
franklin,
if u changed the thermostat and its housing the cause of the car overheating is probably the fan itself. Connect the fan to your battery (disconnect the fan motor's circutry from your car first) and see if it runs. If not the motor is probably burned. Replacing it isn't too difficult. If the fan does run check the voltage from the wires that supply power from you battery. If not that than check the voltage over the wires leading to and from the thermo. Good luck!
Old 06-15-2002, 06:47 PM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
unfortunately i cant help you on this one... all i can say is that it seems to be a feature on 80's BMW's to overheat in traffic. it used to happen to ours and we never managed to get it fixed, ended up selling it... fine car despite that; it would have been nice to keep it so if you manage to find a way to fix it needless to say it would be great
good luck
Overheating pineapple0123 Caravan | Voyager 3 09-02-2009 05:56 AM
my 1997 dodge neon keeps overheating Lavette General Discussion 2 08-23-2009 06:15 PM
1999 contour overhating thermostat has been changed madd802 Contour 4 08-15-2009 08:42 AM
03 Alero overheating/puttering Grizzly5421 Alero 5 08-13-2009 05:44 PM
85' 325e overheating. mistervelasco 3 Series 3 02-02-2004 02:32 PM
