Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-02-2004, 11:18 AM
mistervelasco mistervelasco is offline
85' 325e overheating.
So far I've changed thermostat, roded radiator, there are no leaks and water pump is operational. Even if it is cold out side and on the freeway the temperature reading is still over what it used to be before I went camping. I know the engine runs hotter becuase I can feel it. Could it be my fan clutch? It appears to be working. Or could it be the AUX fan?
ANY SUGGESTIONS?
THANX
Old 02-02-2004, 11:20 AM
lumpydick lumpydick is offline
Banned
Re: 85' 325e overheating.
time to take the old crapper to a scrap yard
bbooooyahhh
Old 02-02-2004, 01:43 PM
mechy1barry mechy1barry is offline
1/could be water pump impellor loose.
2/air lock.release bleed screw on rad and run at 2000 until thermostat opens ,watch the water level.
3/viscious fan faulty.to test with engine running,use rolled up newspaper and see if you can stop the fan when cold,if you can warm up to normal temp (or hot)and see if you can stop the fan again,if you can the coupling is faulty.any probs let me know.
Old 02-02-2004, 02:32 PM
Thanks mechy1barry....I will the test asap. As for the other suggestion by Lumpyd*ck....that wasn't the answer I was looking for, but thanks for trying your best to come up with an educated diagnosis.
