Go Back   Automotive Forums .com Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-07-2001, 07:12 PM   #1
Shooter Boy
Rebuild thoughts.....
Hello,
Guys, need a little experience help here. We are currently rebuilding my R32's bottom and top end, and there is one thing I am unsure of - the crankshaft.
Those running high HP - are you running the stock crankshaft or upgraded unit? We are building the top end to rev up to 10,000 RPM's if we want to, as long as the crank can take it. We are adding HKS 87 mm slugs with HKS con rods.
Thoughts please would be helpful.
Shooter Boy is offline   Reply With Quote
Old 11-07-2001, 08:34 PM   #2
stugtr
Hi Shooter Boy,
I have just finished a full rebuild of my RB26.
However I left the standard crank in so i'm no help to you there although someone who has had a similiar rebuild but toughened up the head with stronger springs etc can rev safely to 9000rpm with standard crank.
I note you are going to use HKS con rods I assume they come with suitably stronger con rod bolts as this is a definite requirement.
Cheers
stugtr is offline   Reply With Quote
Old 11-07-2001, 08:37 PM   #3
Shooter Boy
Well, we checked today, and yes, I believe that HKS Japan told me they come with all required hardware. If not, we will get a set of ARP hardened fasteners.
Yeah, we are getting the Stage 2 Heads package from HKS Japan - they actually told us it would rev to 10K, but I don't think I am going to test it out. ALthough its a drag car - I want to try and make stuff last.
Old 11-07-2001, 08:58 PM   #4
Brenhan
Send a message via ICQ to Brenhan
what specs from the stage 2 did you choose ? I got 280 degree , and supposedly 10.8 mm lift but I can only find 10.2 mm lift in the HKS book so it might be them.
Brenhan.
Brenhan is offline   Reply With Quote
Old 11-07-2001, 09:09 PM   #5
Shooter Boy
Since it is a purpose built drag car, HKS recommended the 304 on intake, and 294 on exhaust. I am trying to remember, but don't exactly remember the lift - has to be around 11 mm.
We are mating this to a T51 R Single turbo for reference.
94 Ranger Tranny rebuild freakyfire05 Ranger | Courier 0 09-11-2010 04:11 PM
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 10:06 PM
4R55E tranny rebuild problem mrstubb Explorer | Explorer Sport Trac 1 05-30-2010 11:27 PM
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 07:30 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 07:38 PM
