Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 08-05-2011, 12:54 PM   #1
gcpint
Cooling fans question
Hello all, been a while since I have posted here but this has me stumped. I will try and make this as brief as possible.
I got my van back after having the head gasket replaced, first to find out there is a vacuum leak which I was able to fix myself but also the cooling fans were not running...anyway I would rather not take it back to the same people (I waited 8 mths to get my van back the first time...long story lol) so I am trying to figure the problem out myself.
I pulled the one relay and jumped the connection and got the 1 fan to run without a problem so I know they are getting power and such...I am assuming maybe they left a connection loose or something so my question is. Where would I find a connection to what controls when the fans come on and off (a control module for the themostat or something?) I am just assuming its something they forgot to connect or something as the fans worked fine before I took it in for the head gasket.
Sorry for the long read but I would really like to figure this out on my own
Thanks for any help!!!
Glenn
Last edited by gcpint; 08-05-2011 at 12:59 PM. Reason: OPPS might help if I said what van...its a 1999 Transport with the 3.4 ltr engine :)
gcpint is offline   Reply With Quote
Old 08-05-2011, 01:17 PM   #2
inafogg
Re: Cooling fans question
Glenn
your test only checks the wiring & fan itself. the fan is'nt getting 12v until you jumped the relay.could be that its just a bad relay,try a known good relay or test the old 1.what happens when you turn the ac on, do both fans come on?
as far as the vacuum leak,smoke test is a good way to locate if its a small leak.spraying the v/lines while running will also help to find.can you hear the leak,or is it causing idle problems.
i agree i would'nt want to take it back to a shop that took 8mths to get it done
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
Old 08-05-2011, 06:14 PM   #3
gcpint
Thanks for the help once again
I found that there was a lead off a sensor on the side of the rad...simple fix
Also the vac leak ended up being a hose disconnected from the PCV valve which you could not see as it was behind everything...both issues have been fixed Thanks again!
Old 08-05-2011, 08:20 PM   #4
inafogg
good to hear,thats for the fix
Live For Today
Yesterday is gone,
Cooling Fan sensor.....please read! Baffled! diecast92 Engine and Transmission 10 07-31-2011 11:23 AM
99 T&C (Another) cooling fan question SlimJimRD Caravan | Voyager 7 08-04-2010 09:11 PM
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 09:03 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
