Go Back   Automotive Forums .com Car Chat > Mercury > Grand Marquis
Old 04-22-2011, 02:34 PM   #1
kevin23
Heater/ A/C blower won't shut off
2007 GM, 42,000 miles
The blower for the heater/ A/C runs at high speed all the time. Even after turning every thing off it still runs. No matter what I do it refuses to stop running. The noise is ,well annoying. It does have the digital controls. The only time the blower stops is when the ignition is off.
Any suggestions as to what to do to fix it?
Thanks.
kevin23 is offline   Reply With Quote
Old 04-22-2011, 02:58 PM   #2
FishFind
One Hot Shot
Re: Heater/ A/C blower won't shut off
see if it is the switch? pop the dash cover off and unplug the switch see if it shuts off.
FishFind is offline   Reply With Quote
Old 04-22-2011, 08:03 PM   #3
way2old
TOKEN HILLBILLY
way2old's Avatar
Possibly the blower motor resistor. If it is shorted across the resistors it could cause the problem. Also there is a module that controls the fan. A high end scan tool can read all the modules for trouble codes.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 04-23-2011, 02:08 PM   #4
kevin23
Can anyone tell me where the resistor is located? I have looked under the hood on the firewall around the blower housing. Nothing. Also took off a plastic panel below the glove box and again found nothing that looked like a resistor.
Thanks
Old 04-23-2011, 08:08 PM   #5
way2old
TOKEN HILLBILLY
way2old's Avatar
Is this a manual system or the Electronic controls?
Old 04-24-2011, 04:01 PM   #6
kevin23
Electronic controls.
99 Montana Blower Won't shut off. wormfriskie Montana/Montana SV6 3 09-30-2009 10:57 AM
Blower won't shut off Eccentricity Deville 5 03-01-2006 01:00 AM
1992 Deville Blower won't shut off joeplan1 Deville 2 11-12-2005 01:09 AM
96 A/C Blower won't shut off mcqueary Aurora 1 08-07-2005 09:38 PM
94 Buick Park Avenue Blower Won't Shut Off mladyslady Park Avenue 5 04-26-2005 01:30 PM
