Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 12-19-2005, 12:07 PM
Eccentricity Eccentricity is offline
Blower won't shut off
Hey, I've seen that some people have had this problem before. However, I just want to double check with all of you before I go out and start buying parts. I have a '91 deville, and the blower just won't turn off unless I disconnect the wiring. Any help would be appreciated. Thank you.
Old 12-19-2005, 01:11 PM
DFBonnett DFBonnett is offline
Likely the blower control module. You can access it from under the hood on the passenger side on the blower housing.
Old 12-19-2005, 06:52 PM
Thanks. Any idea where I can find the parts at? Or find the part numbers?
Old 12-20-2005, 08:06 AM
Try..
www.rockauto.com
www.gmpartsdirect.com
www.gmotors.com
dealer (if you don't mind overpaying)
local auto supply store
Old 02-21-2006, 08:53 PM
gmtechnician gmtechnician is offline
Re: Blower won't shut off
I know I have used a module out of a buick and it was the same part only it
cost less money for buick than Caddy.
Old 03-01-2006, 12:00 AM
ilgoldstein's Avatar
ilgoldstein ilgoldstein is offline
A good auto parts store should have the relay, and it's just a matter of locating it under the hood. The same kind of relay controls the cooling fans.
