Go Back   Automotive Forums .com Car Chat > Racing > Drifting
Old 12-19-2003, 12:02 AM   #1
ColeIketani
ColeIketani's Avatar
Send a message via AIM to ColeIketani
How to overcome understeer in an FWD
Any ideas?
As of now I've been swinging the back of the car around, but there must be a better way...
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
ColeIketani is offline   Reply With Quote
Old 12-19-2003, 12:06 AM   #2
SchuberT
SchuberT's Avatar
Re: How to overcome understeer in an FWD
besides hand/e-brake, i know of none....
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
SchuberT is offline   Reply With Quote
Old 12-19-2003, 12:08 AM   #3
integra818
integra818's Avatar
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Thicker rear anti-roll bar, smaller front anti-roll bar. Increase tire presure in the back, and last but not least...drive better. That's all the advice I can give.
integra818 is offline   Reply With Quote
Old 12-19-2003, 12:20 AM   #4
Racingwannabe
Send a message via AIM to Racingwannabe
Well there is a driving technique called left foot braking. I think the idea is that you are turning, ok and now u have feet on both the brake and accelerator, so when you understeer you can press the brake a little and then start accelerating again. I dont remember how it goes but its something like that.
I want to be a sleeper.
Racingwannabe is offline   Reply With Quote
Old 12-19-2003, 12:23 AM   #5
jdmkenji
ways to create oversteer:
1. put shitty tires in the back of your car
2. weight loss in the rear of the car
3. put grippier tires in the front
4. put thick sway bars in the rear
if all else fails, spray water on your rear tires!
there you go...
http://mightywingman.co-jp.us/
jdmkenji is offline   Reply With Quote
Old 12-19-2003, 12:24 AM   #6
ColeIketani
thanks, ya I know about left foot braking and it works, but course I'm going to need more practice
Old 12-19-2003, 12:41 AM   #7
2strokebloke
In Stereo where available
2strokebloke's Avatar
Re: Re: How to overcome understeer in an FWD
Lift off of the gas, and you get a very shallow oversteer on most FF cars. If you have a stiff anti-roll bar on the rear, you can get more oversteer than you want (I can honestly say that I've gotten nastier oversteer out of my '82 Tercel then I've ever had to deal with in any of my rear engined cars!)
I also detailed an interesting techinique for using understeer to create oversteer in the thread in this forum about "snow drifting" but it's a pretty tricky technique to use on a dry surface.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
2strokebloke is offline   Reply With Quote
Old 12-19-2003, 01:04 AM   #8
Layla's Keeper
Supermodified
Layla's Keeper's Avatar
Also, try dialing a few degrees of toe-in into your rear suspension. It's a trick ACR Neon drivers use to great degree and really helps free up an FF chassis. Also, if you can, zero out any rear camber you might have.
After that, it's just like the others have said; left-foot braking, stiff rear sway bar, and a few more pounds of pressure in the rear tires.
A friend and I did this list of setup stuff to a Geo Storm with great success. Really helped in autocross.
Proud Owner/Operator of Haven Raceway and Hobby!
Layla's Keeper is offline   Reply With Quote
Old 12-19-2003, 01:10 AM   #9
ColeIketani
thanks for help guys, any other ideas?
Old 12-19-2003, 09:51 PM   #10
integra818
integra818's Avatar
For now, increase the rear tire pressure and see where you're at.
Old 12-20-2003, 11:00 PM   #11
2of9
snow is your friend...hahhahheheh
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
2of9 is offline   Reply With Quote
Old 12-24-2003, 02:16 AM   #12
BullShifter
BullShifter's Avatar
All types of drifting tips - http://www.driftsession.com/drift_te...oeshifting.htm
Learn suspension in & out so you can get the proper set-up --- get a book called How to Make Your Car Handle
Go to a closed course & practice - dont forget a shit load of tires.
BullShifter is offline   Reply With Quote
Old 12-24-2003, 02:54 PM   #13
2strokebloke
Actually, with FWD you'll find your tires wear very little at all (a bonus over FR) because you're not spinning them to break traction. However, if you do it alot, they'll wear irregularly.
Old 12-25-2003, 07:03 PM   #14
$ilverbullet
Send a message via AIM to $ilverbullet
pssst wanna know a little secret?
make ur rear suspension stiffer than your front and your car WILL oversteer. But becareful, you wont handle as well as having stiffer front.
My 1993 240SX SE Fastback
$ilverbullet is offline   Reply With Quote
Old 12-26-2003, 01:31 AM   #15
raysoh8
raysoh8's Avatar
lets see..
less toe in at the rear
softer springs at the front, stiffer at the rear
raysoh8 is offline   Reply With Quote
2000 MonteSport... How to change fwd turn light? FabricGATOR Montero/Shogun/Pajero 1 06-07-2009 03:43 PM
foocked up transmission prevention...how can we overcome? joyofsix LS | MKZ 0 01-29-2006 08:01 AM
How the heck do they convert FWD to RWD AlexB Street Racing 18 08-08-2004 09:24 PM
How can to get over Fwd RACER D12 Street Racing 27 02-23-2003 08:05 PM
How to launch a FWD car.... fatninja19 Street Racing 12 09-15-2002 11:30 PM
