Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 11-11-2010, 09:12 AM   #1
crazyduetoiowa
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
intermittent starting issues
I have a 03 s-10 4.3 4x4. Some days it will not start. It powers evertything up normal, fuel pump runs, but when you turn the key to fully start it does nothing. No attemp to start at all! I usually have to wait 10-20 mins and it will eventually start. I replaced the ignition switch last weekend, and this did not fix it. What do I look at next?
crazyduetoiowa is offline   Reply With Quote
Old 11-12-2010, 01:50 PM   #2
viggy58
Re: intermittent starting issues
maybe a passlock issue. did you mark sure all the harnesses are plugged in?
check for 12 volts at the starter.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
viggy58 is offline   Reply With Quote
Old 11-13-2010, 09:58 PM   #3
tjski
I am no expert, but I would check you connections on your starter. Also check the grounding wire on both ends.
tjski is offline   Reply With Quote
Old 11-21-2010, 10:10 PM   #4
jalopyjoe
Maybe it's your starter. Does it even turn? If it cranks, then it's something else.
98' S-10 4x4- Nice Truck
92' Previa
Now a 99' Camry
jalopyjoe is offline   Reply With Quote
Old 11-21-2010, 10:18 PM   #5
danielsatur
During the no start condition, are you getting battery to the Lights, and horn?
danielsatur is offline   Reply With Quote
Old 11-22-2010, 01:42 AM   #6
jalopyjoe
Originally Posted by crazyduetoiowa View Post
....It powers evertything up normal, fuel pump runs, but when you turn the key to fully start it does nothing. No attemp to start at all! I usually have to wait 10-20 mins and it will eventually start.
This sounds like it's the starter. From what you are saying, it doesn't even turn but everything powers up normal. Try tapping the starter with something like a hammer. Don't beat it though. Then try starting it.
92' Previa
Now a 99' Camry
Old 11-22-2010, 01:46 AM   #7
buyho
Wish today were Friday,but Monday...
classic ugg
buyho is offline   Reply With Quote
98 Gmc Sonoma Intermittent Starting Issue RON FREY Sonoma | S-15 5 02-11-2011 03:19 PM
Rigging relay to starter to overcome intermittent starting issue on 4x4 Toyota jake jake Pick-Up 3 07-21-2007 09:19 PM
94 Buick Skylark, intermittent starting issues... Help! A_Bartle Skylark 3 03-07-2007 07:56 PM
'99 Intermittent Starting issues - gas/spark? jh2301 Expedition 2 11-09-2006 10:20 PM
94 LeSabre with intermittent starting issue oscwby LeSabre 2 04-20-2005 12:29 PM
