Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-15-2007, 08:31 PM
jake jake jake jake is offline
Rigging relay to starter to overcome intermittent starting issue on 4x4 Toyota
i ahve read where you can rig a relay to overcome the intermittent starting issue that some toyota 4x4 pickup trucks have. anyone know the exact instructions how to rig it up?
can you post the directions.
i have an 89 4x4 V-6 automatic toyota pickup that has the intermittent starting problem. some say they have totally cured this problem by rigging up the special relay to the starter --trying to figure out how one does this
Old 03-16-2007, 11:46 AM
Re: Rigging relay to starter to overcome intermittent starting issue on 4x4 Toyota
i think it somehow involves running a wire from the cold start injector to a relay , then running another wire from the relay to the solenoid [and disconnecting the existing solenoid wire], and then running another wire from the relay to the postive battery post.
does this sound like it might work? anyone try this for an intermittent starting issue on a 4x4 toyota?
Old 03-21-2007, 11:22 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Assuming your problem is not due to the neutral safety switch, you can wire a momentary pushbutton to the starter solenoid.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-21-2007, 08:19 PM
fallbrookdave fallbrookdave is offline
I had the same problem on my 85 truck. It was a wire in the harness behind the ignition switch. I just put a nice pushbutton on dash. Battery to starter solinoid, like previous post mentioned. I would turn key first, thinking that pushbutton alone may not turn EFI fuel relay on. I would turn key for a couple seconds and then push button. We replaced the igition switch recently and it is now fixed.
