Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 08-13-2005, 09:01 PM
RON FREY RON FREY is offline
Question 98 Gmc Sonoma Intermittent Starting Issue
I Have A Intermittent Starting Problem. 1998 Gmc Sonama 130,000 Miles. This Has Been Ongoing This Summer. Vehicle Starts And Stalls When This Happens. Leave The Vehicle And Come Back , Then The Vehicle Most Proably Will Start. The Longest Wait Was Several Days.
Again, The Vehicle Runs Good Till I Turn Off And Come Back To It After A Time. Doesn,t Happen So One Can Plan On It Not Working. Fuel Pump Nose Is Audible.
My Experience From the 60's And 70's When This Would Happen To A Vehicle Was A Defectice In Line Resistor In The Coil Circuit. The Vehicle Would Run From The Starter Selonoid 12 Volt Feed To The Coil But Not Thru The normal Run on the Ignition Switch.
I Have A Local Shop Set Up To Help But I'm Waiting For The Engine To Not Start When I Shut Down In Their Lot. But It Starts Ok When I'm There.
Old 08-13-2005, 11:26 PM
drdd's Avatar
drdd drdd is offline
Re: 98 Gmc Sonoma Intermittent Starting Issue
have you ever done a tuneup?
Old 08-14-2005, 10:44 AM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Sounds like your EGR valve is sticking. When mine was sticking it would run fine and when I shut it off it was hard to start, or would back fire till it died. I would try cleaning that before you run through your electrical system.
Old 08-29-2005, 05:12 AM
Cool Re: Re: 98 Gmc Sonoma Intermittent Starting Issue
Thanks for your advise, I'll check the EGR VALVE.
BUT, THERE HAS BEEN NO ROUGH IDLE, OR OTHER ENGINE MISFIRES, The engine just seems to start and then kills.
Old 10-29-2005, 06:02 AM
I took the vehicle to a local shop , he put 80$ part in and gave up, he hauled 98 Sonama to local GMC dealer and I got billed 700 dollars for a antithief device, a new program, a ignition switch and tumbler with key. Oh well, the vehicle has started OK since!
Old 02-11-2011, 02:19 PM
jlynn357mag jlynn357mag is offline
I have a 98 as well it did the same thing 3 thing to check ground strap bottom passenger side of the block but its probably the starter the nut on the main power supply on the starter came lose or the solenoid is cracked good luck
