Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Nissan
Primera | G20
> Maintenance
View Full Version :
Maintenance
Pages :
1
2
3
bad transmission
Is O2 Sensor Fault Code 100% Correct?
Fuse Diagram
Foglights not working!
Fuel Economy & Obd-1
New Here please help
P10 firewall
Wandering revs...
Help!!! Trunk Not Locking :*(
Strange starting problem
Belt Replacement for P10?
auto tranny fluid change
electric window motor
G20 newbie needing some advice
Knock Sensor...you should read
Home car lifts
burst of thrust/ hard shift when auto tranny shifts into second gear
Motor mounts needed!
Thermostat and waterpump.
OverHeating Please help!!!!
Manual Transmission Oil
Alignment issues
headlight problems
g20 engine noise
Idle question...
drivers side panel/trim
Need new engine mounts?!
pricing on window & sunroof motors
Just bought a G20, now I got questions
What is LSD ?
Stripped Lugnuts HELP
Front Axle Outer CV Boot
Car "creaks" when going over bumps in cold weather
Fuel Filter replacement.
OBD-II diagnostic codereader for sale on Ebay!
Infiniti Oil filter vs Sentra SE-R vs Altima filter
What octane gas?
Should I get a newer high milage G20 or older low milage G20
Whats up with my fogs?!!!? HELP
seatbelt light comes on randomely and also stays lit...
horn and cruise stopped this weekend....ideas?
Replacing tranny...which has LSD?
Throttle Body Cleaning...
Hand brake light stays lit
dynomat?
Need some Help with Fuel Filter Change!
Looking for FSM
95 g20 5spd idle problem
Sound Coming From Somewhere?
Installing New Spark Plugs
Is It Just Me Or Is The P11 Like Hella Loud?
How To Remove Driver Side Door Panel
?? webs of sr20de mantenaince, repair ...
"POWER" light lit on hard acceleration
Automatic tranny filter?
Starting Probs.
Thinking about purchasing a G20
horrible noise when racing
Obd-ii
How do you lower the clutch pedal?
help noises Primera GT SR20DE /Inf G20
Why Transmission makes car bump when switching to second?
Hard to remove the alternator
I changed my own oil!!!
power windows
G20 Brakes
Odb-ii
Engine Off Clicking starts
AAC Valve / Dropping Idle... Anyone else?
Strange noise after each engine start
im soooo pissed
What Is The Clicking Noise???
yes.. yes it was the o2.. but now
HELP!!!!! Transmission Noise
Loose Hood
needs some advises on repair....thx
Primera/G20t Bulb Specifications ?
Solid or Cross Drilled Rotor ?
Has Anyone Had to Replace Hub Bearings
Maintenence Fluids?
Is there a Problem with this SR20DE ?
A/C Heater Control Unit not lighted up
Starting Issues
Emissions Systems
differential oil seal experience
ABS problems on pre 93.5 G20s?
93.5 New Purchase with Rust
Rotors and brake pads
Windshield arm link
Anything to do with my thermostat??
Help!!!!!
93 or 93.5
Starting woes
Need help...idle problem
Lower ball joint
Replacing upper suspension arms
Trouble Starting
Does anyone know proper way to bleed brakes on P11 and proper break-in on new pads??
my car is the biggest p.o.s
HELP Tranny Guru's!! Tranny pan is off as we speak!!
fuse problems
Ventilation air filter for AC/heating
Which Spark Plugs to Order
How to Clean JWT POP Charger ?
P10 Whine under the hood...help?
My car won't start
Question about painting
How to Change Fog Light Bulbs on P10?
weir noise
Car's being weird + Check engine light just came on.
B13 Brake Upgrade
How Do You Remove a EGR Solenoid Valve????
Is (GL-3,GL-4, GL-5) ok or do I need ONLY GL-4 gear oil?
cold engine start tapping noise???
Engine Squeak after turning off ignition
popping noise on door close
clutch pedal feels hard and is high
New for me '93
Anyone ever have to replace an ABS wheel sensor??
ABS problem
just testing skip it
how much oil does the tranny hold? (auto 94 g20)
grinding noise from front
Subframe Problems
Is the G20 tranny/clutch same as Sentra in FSM manuls???
Smog in CA
Anyone tried this for drying?
Part Numbers!!!!!!!!!!!
Oil Light Mystery
Starting problems... again....
Unfixable Alignment - Bad Upper Links?
trans-to-axle seal installation
Bad Vibrations
Floor Jack Location
Gas + Distance
MAF tube question
Radio static from rear defroster
Gas Gauge accuracy?
P10 Seat Motors!!
CV Joint
anyone ever tighted their belts(on car!)
whining noise on steering
Brake system
FSM Factory Service Manual 1991 G20
Can't get car out of park
springgy noise? comming from rear
searching for good G20 parts
How do I remove P10 tails?
are g20's made to last?
N/A '96 P10 replacement clutch for minor mods???
Hks Springs, Ride Comfort?
Help
Cruise control problems
lights
squealing
window lock light
climate control lights
A/C Whine or Alternator
Starting Problem
Grinding noise from right front wheel ????
sulfer/gas smell
G20 hard to start
P10 Hesitation
HKS springs/Ride and comfort
weird idle on my p11
Jerk during shift from 1st to 2nd gear
Who Makes Steel Braided Brake Lines For The P10 Model G20's
How to remove passenger side heating vent
early 93G20
How to remove window tint film?
Steering Wheel Alignment
Sunroof Gettin Stuck Help!
ABS FAILURE! (Help Asap!)
93.5 G20 Starting Problem
Caliper lubrication
Door Molding
bad o2 sensor = bad idle?
front seal?
Argggg!!!!
I can't stop that whistle!!!
replacing brake pads/shoes
Help!! Car Wont Start
REeasons why a CV joint would break
Coolant Leak
possible tranny problems?
Help: Checking Transmission fluid
Help for 92 G20 Alternator and coolant drain
brake bleeding
Shafted again
Indicator Lights On
Brake discs for 93.5 G20
93.5 G20 Cup HOlder/ Aftermarket???
does any of you know how to regulate the p11 clutch?
Grease for the sunroof.....
Rough Idle
Careful when changing to manual.
Interior Rattles anyone? Help!?!
Only right side of moonroof works on P10
Light ticking sound coming out of front passenger side wheel
Trunk Latch
How to bleed brakes on my 99 P11
FYI - Charcoal Canister and Purge Valve
How to change belts?????Anyone?
lighting harness troubles
Ventilation Air Filter
15k Maintenance
Corner Lights
just got my car back...
No more adjustment avail on the clutch
AC control lighting
Changing Tranny Oil/Fluid
P10 alignment
alternator + check engine?
Idle problem...
Lots and LOTS of problems.
Smokin in back
How do you get at the clearance lights on P10
Power slot rotors
How to change shift cable
Dimming of the lights
Tie rods.
p10/1995/G20 Fuel Pump part #?
Engine noise....
Bad Bad Bad Milage....
Need new brakes
wierd sounds...
Multiple Oil Leaks?
Need info on rebuild...
brake/axle questions
rough idel
Screwy Electrical Problem, LOL!!!
Fog Lights
Where can I buy
Tranny Problems
Defa warmup system
Vibration - Left Dash
Door mouldings/Rubbers
Engine Fan
cause of blown head gasket?
Start-Up Noise
is my starter or alternator busted? or perhaps my batterey?
Erratic Tach
g20 modifications
power seating
Flooded spark plugs
valve adjustment?
dead or dying p10
oil filter bracket??
how did i break my g20?
outer boot replacement questions
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
