View Full Version : Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. The Air Locker Installation
  2. Drivetrain Mileage?
  3. Questions on Mats
  4. (new guy) - body lift vs suspension
  5. tires
  6. 2003 Nissan Xterra wiring diagram
  7. '02 X For Sale in West KY
  8. Why won't my QX4 stay idling while cleaning throttle body?
  9. 03 Xterra engine failure
  10. doess 5.25 speakers fit???
  11. Xterra differentials compatible?
  12. Locking Differentials?
  13. Goodyear Wrangler Rt/s
  14. How to?
  15. Aftermarket Exhaust for 02 QX4
  16. Prospective buyer ?s: 90-95 Pathfinder-->
  17. will a 265/75/16 bfg a/t fit in the spare tire location
  18. rock sliders
  19. steering question for 05 X
  20. 2005 keys
  21. E brake not holding
  22. Hid
  23. Where to offroad?
  24. Can't remove tire.?.
  25. Best tire
  26. tire size on 17" SE S/C
  27. Problem with Keyless Entry
  28. XM Radio in 05 X
  29. General Question about Qx4
  30. throttle body spacers
  31. Qx4 NAV CD trade MCA 8 trade for MCA9
  32. Pathfinder 2000 SE
  33. 4x4 Patfinder 2000 SE
  34. Front Door Panel Removal
  35. Tranny Question
  36. Stereo System
  37. TD27 engine
  38. is the under body of your x pretty rusty
  39. It just died
  40. Hotter Than Hell - hot air through vents??
  41. oil preassure switch leak?
  42. K&N Air Filter
  43. 2001 roof rail crossbars
  44. Front Marker Light replacement???
  45. Delay shifting into drive
  46. hows the 256 engine?
  47. VQ35 engine help!!!
  48. need some help in New York
  49. Engin Type??
  50. Pathfinder 2000 0r 1999????
  51. Coolant Leak/It Just Popped out!!!
  52. Clanking Noise on breaking
  53. 2001 Pathfinder Air Vent Issues
  54. finaly put tires on. Thanks for all the info
  55. Loud noise from front end 2000 Xterra
  56. Squealing drive belts
  57. hill descend assist on '05 OR
  58. 2003 Nissan Xterra w/Rock.Fosgate factory system
  59. anyone put there 3" suspension lift in themselves.
  60. Alarm installation
  61. 2005 xterra rims
  62. '98 Pathfinder - Power door locks and windows fuse?
  63. need help. is this a good deal
  64. FS: 2000 - 2004 Xterra Roof Fairing & Basket
  65. wife backed in to cement block. now hatch doesnt open. need help
  66. do 305 70 r16 tires fit on stock rim?
  67. Problems
  68. I can't get my stock stereo out.
  69. PCV Valve
  70. 05 xterra owner who can't get his stock radio out!
  71. 05 X Tow Hitch SAFETY RECALL NOTICE
  72. so whats better off road. manual or auto
  73. cheapest suspension lift.
  74. will these fit on an 01 x (ebay)
  75. Add Day-time Running Light in 01 QX4
  76. Is it true that there is only 1 grease fitting on an x
  77. 4-WHEEL PARTS store DENVER
  78. ShrockWorks Bumper
  79. i want to add amp but keep stock 6 disk. (how do you run a line)
  80. rugged trail T/A
  81. 94 PF 4WD M/T shutting off while driving
  82. Xterra front bumper - Scratch repair?
  83. wheel spacers. are there any down sides to them.
  84. 235 75 16 tires the whole set for $50. should i do it
  85. 94 pathfinder won't start/blows meter fuses
  86. modding a supercharged xterra
  87. WTB '02 Xterra parts
  88. Xterra Door Removal?
  89. My Ride
  90. 95 Pathfinder auto trans gets stuck in 3rd
  91. 94 Pathfinder Starter Issues
  92. Help!!!
  93. need help with sagging while towing my boat
  94. I need some new Interior Trim
  95. Air conditioning
  96. 1988 izuzu rodeo / 3.2 dohc
  97. roof rack for '05 - Yakima or Thule?
  98. Clutch Fan
  99. how to change front 2002 signal lights?
  100. Thread ratings on
  101. engine service light is on
  102. Check Engine Light
  103. how to do a radiator flush?
  104. how to change tranny oil?
  105. solid axel or not
  106. Warrenty
  107. clutch/tranny problems???
  108. anyone have pics of x with 31 and or 32 with stock lift
  109. 2004 Xterra SE OEM Air Box
  110. switching between 2wd and 4wd?
  111. can someone photoshop this
  112. 01 Pathfinder Pinging
  113. Slight Vibration
  114. Xterraparts.com (Courtesy Nissan)
  115. Grinding noise from the front axle in an infiniti qx4
  116. emisions test fail
  117. belts
  118. 91 pathfinder gas milage
  119. mud kings
  120. 70's beetle sound coming from engin area
  121. Better my gas mileage?
  122. Vg30?
  123. Shrockbars for 05 X
  124. 2001 pathfinder power windows
  125. compressor clutch
  126. 100k mile question
  127. #6 spark plug 2000, 3.3l
  128. #6 spark plug 2000, V-6 3.3l
  129. RPM issues... MAF???
  130. qx4 mileage
  131. K&n filter: will it help gas mileage?
  132. ticking
  133. Tires squeal
  134. Need help removing washer reservoir
  135. please help b4 warranty expires - Prob starting my 02 path
  136. just got my new x
  137. 98 Pathfinder light engine clicking after start up
  138. both front brakes keep locking up
  139. Clunking sound when changing into reverse.
  140. how much would it cost to have the timing belt changed
  141. any change fluid in transfer case
  142. which gear oil to use for differential
  143. Aiming Headlights 2005 Xterra
  144. AC went south on me!!!!!
  145. Part needed
  146. Fix for exhaust rattle on 04 Xterra
  147. 1995 PF signal flashers not working?
  148. replacement suspension ?
  149. Lifts
  150. 1993 Pathfinder V6 Won't Start
  151. AC Warranty
  152. 95 Nissan Pathfinder wire harness help?
  153. '05 S model Radio advice
  154. 2002 Pathfinder Brake Noise Question
  155. programming
  156. installing radio in truck
  157. air conditioner operation in defrost/defog mode
  158. Pathfinder "puttering" sound w/acceleration?
  159. Hi
  160. Rust on the back of my X
  161. windshield washer fluid reservoir
  162. Issues with new 05 OR X
  163. 98 QX4 - boost sensors
  164. 2001 Nissan Xterra, 2wd
  165. 2005 xterra speaker sizes
  166. 95 Pathfinder Brake Job
  167. hubs acting up?
  168. Pathfinder Blower for A/C doesn't work...
  169. Do not pass go(Go Over It), Do not collect $200 rather spend it....and alot more
  170. 98 pathfinder tailgate won't open
  171. Stolen 2005 Nissan Emblem
  172. 2001 Izuzu Rodeo
  173. 2005 Xterra Steering Wheel ?
  174. cb radio
  175. 2002 Pathfinder Bose System into 2001 Pathfinder LE?
  176. 2001 Pathfinder front end suspension noise
  177. Painting the runners?
  178. fuel gauge spiking past "full"
  179. New 05, 2nd XTerra, New Member, First 4x4
  180. 12V Car Computer & Touch Screen for GPS Navigation
  181. 2005 Seat Covers
  182. what do you think of my xtrail kit
  183. Dash Problem
  184. Rear sprayer
  185. Hey Schludwiller!!!!!!!
  186. winter tire
  187. hard knocking sound
  188. Hitch Install on 05 X?
  189. Changing the Timing Belt
  190. Front Towing Holes
  191. In dash cd changer
  192. Sunroof wont close
  193. Hard to shut doors
  194. My ECXC5 pics
  195. 2005 OffRoad Shocks
  196. 2005 Xterra - New Member
  197. Foglights on the "S" model
  198. Compass & Temperature Display
  199. 05 Pathfinder seats & suspension
  200. 17" SC Rims Trade
  201. PA speaker
  202. SuperCharger Gas Premium or Regular
  203. ECXC '05 Pictures
  204. towing my 2002 x
  205. will 245/75/16 fit on a stock xterra with torsion tightened up
  206. '99 Nissan Pathfinder Stereo Install Questions
  207. A/C fan noise
  208. Calmini Heavy Duty Shackles
  209. how big of a tire can you put on a 3 inch lifted x
  210. please tell me if this kit is good
  211. Rear Brakes Overadjusting Themselves
  212. Tail light fuse location - '98 Pathfinder?
  213. 97 nissan pathy, won't start! Help, Please
  214. how is the ride after tightening the torsion bars. what would the shop charge
  215. how hard is it to make an n/a x a supercharged x with factory supercharger
  216. what was nissan thinking when they put the alt at the bottom of the truck
  217. tranny problem????
  218. Aftermarket exhaust for an 01' PF
  219. CDR Playing Problems on Bose (01' PF)
  220. 14 X 225/60 14X235/60 wanted
  221. Need Help soon
  222. A/C shutting off.
  223. Problems with Rear Water Sprayer
  224. Body Lift
  225. i need a rear bumper. where would i go besides the dealership
  226. 97 Pathfinder / squeaky, squealing
  227. ????Shocks/ Struts 98 Infiniti QX4 ????
  228. how do , do a front brake job
  229. What is the PCT fusible link?
  230. 2000 Xterra No A/C
  231. '01 Pathfinder - suspension noise
  232. FS: Snow Chains
  233. Service Engine Light Error........
  234. Liberty, WA
  235. How-To: XM Radio Install
  236. Pathfinder Muffler Help...
  237. 1992 Pathfinder SE *For Sale*
  238. 98 QX4 metallic rattle around 1k and 2.4-3k rpm?
  239. 2001 Pathfinder cigarette lighters
  240. 2001 Pathfinder rear window release?
  241. Keyless Remote - FOB
  242. 1995 Pathfinder Blowing Meter Fuse
  243. 2001 Nissan Xterra, 2wd
  244. 2000 Xterra Timing Belt and Rattling/Vibrating Sound
  245. Pathfinder 2001
  246. 95 Pathfinder Alarm Problem
  247. Lift
  248. new 05 xterra
  249. Locker preference?
  250. 05 xterra moonroof
