Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 12-26-2009, 02:39 PM   #1
littleman22
Cavalier RWD conversion kits HELP
Are they out there,or would the s-10 drive train work of the Z24 engine tranny bolts, any1 out there tryed or what, becuz i wanna make a Z24 show car that is RWD
littleman22 is offline   Reply With Quote
Old 12-28-2009, 08:10 PM   #2
J-Ri
J-Ri's Avatar
Re: Cavalier RWD conversion kits HELP
My best advice is to rethink your plan. Cavaliers aren't really show car material. Don't get me wrong, they're good cars, but if you want a show car get a Camero or Corvette. It can be done, but you have to build a frame (FWD unibody structure won't hold up to RWD), tunnel the body for the D/S, build tons of custom mounts/brackets, the work just goes on and on. I think there's a thread in "engineering/technical" about this... way too much work. Between everyone who responded, there must be a hundred major modifications... basically you're building a car from scratch because nothing is a direct (or even close) fit.
But to answer your question, no kits for this, and an S-10 drivetrain would probably be the closest fit.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 01-06-2010, 07:26 PM   #3
CarolinaCavy
Go to SmithPerformance.com I think they might have what your looking for. I have a 1996 Z-24 and it would be cool to do this but considering the money and time it's probably just best to buy another car, but on the other hand it would be badass.
CarolinaCavy is offline   Reply With Quote
Old 05-15-2010, 08:27 PM   #4
Joe Wilson
Just go to your nearest drag strip and check out the V8 Cavaliers running there. At almost any strip you'll find several of them and they usually have tube frames under them, an expensive proposition.
Joe Wilson is offline   Reply With Quote
Old 03-08-2018, 11:15 PM   #5
Civicslayerz24
I have a 1990 cavalier z24 with a 3.1 v6 and I'm working on converting my car to rwd with a tranny and axel from a 89-90 camaro rs with a 3.1 if that help u at all
Civicslayerz24 is offline   Reply With Quote
