| Latest | 0 Rplys |
#1 | |
98 suburban electronic transfer case won't shift
I have a transfer case problem.
1998 GMC Suburban 5.7L RPO NP8 - 114Kmi LEDs do not light on 2Hi, auto 4WD, 4Hi or 4Lo. Sometimes neutral LED blinks. Appears to only run in 2Hi, occasionally "slips". "Service 4WD" does not light up (except during instrument panel self test when starting the vehicle). This all started while on a trip to Santa Barbara last week. Took it to a tranny shop there, they read out the following error code, reset it and it did not recur for them: "CODE#U1026 loss of class 2 com w/auto/trans..." Either there were no transfer case error codes or they were unable to read them. I read a similar thread on this forum, a GM bulletin was posted indicating a weakness in the stock design. Per the bulletin, I plan on replacing the detent plunger with the teflon coated part. Where exactly is the detent screw located? Is it on the bottom of the transfer case next to the motor/encoder? Would like to know if the motor/encoder is bad before replacing it. Or should I just replace it based on the age of the vehicle? So far, I have removed the transfer case motor/encoder. Is there a way to test this off of the vehicle? Will the motor run on DC? If so, how much current is required? Alternatively, is it adviseable to hook the cables back up and run it on the vehicle with the motor not driving the transfer case shaft? Are there any other diagnostics I should perform? Thanks, -- Chuck |
#2 | |
Re: 98 suburban electronic transfer case won't shift
That code (U1026) indicates a loss of communication on the Class 2 Serial Data system from the ATCM (Automatic Transfer case Control Module). This can be caused by loose connections, bad pins, shorted wires, etc. It can also be caused by a loss of power to the ATCM.
3 fuses supply power to the ATCM. All are in the I/P fuse block. 1. Gauges--Fuse #4 10a (hot in run) 2. 4WD--#24 20a (hot in run) 3. T Case--#2 20a (hot at all times) REPLACE these fuses, even though they may look good, and post back. PS: Should have said replace one fuse at a time starting with the T Case then the 4WD and last (though I doubt it) the Guages fuse.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser Last edited by 777stickman; 07-10-2007 at 05:53 PM. |
#3 | |
Stickman,
Replacing the transfer case fuse #2 fixed the problem. The old fuse looks good, I'll test it on a milliohmmeter on Wed. I only wish I had replaced the fuse before I removed the shift motor and front driveshaft. Many thanks for shedding light on this problem. I owe you one. If you're ever in the south bay area of Los Angeles, please contact me by replying to this thread, I'll buy you a pitcher or two. -- Chuck |
#4 | |
Hey Bones: Glad I could help. Replacing that T Case fuse may have just reset the ATCM and cleared the code. Keep an eye on it and let us know if anything else happens.
And thanks for posting back for us all to gather more info.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
#5 | |
Any other ideas. Mine is doing the same thing and unfortunately the fuse replacement did not solve it for me. What should I do next? When I turn the key on, my 2wd hi light comes on for about 3-4 secs and then turns off. No other lights at all.
Thanks |
#6 | |
![]() Join Date: Sep 2004
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date. Start a new thread to address the issue you are having. You can link to this thread if needed.
From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
