| Latest | 0 Rplys |
07-14-2006, 08:33 PM | #1 | |
ABS, Trac Off Light Keep Coming On
I have a 2000 Grand Prix GT. The ABS and Trac Off light keep coming on more and more frequently. There is no difference in braking performance. The other day, I heard the anti-lock brakes kick in at the same time the ABS and Trac Off lights were on. The front passenger wheel bearing was replaced about six months ago. Any idea's? Thanks
07-14-2006, 10:14 PM | #2 | |
Re: ABS, Trac Off Light Keep Coming On
Do a search about that and you should come up with a whack of info. Basically I seem to recall it's a bad ABS Sensor. Did it start after your bearing was replaced? What brand did you use? It happens on my wife's car when it rains, but I've yet to get under there and find out why. Pray it's just a nicked wire somewhere...
07-15-2006, 05:55 AM | #3 | |
stupidity should hurt
It is most likely another bad hub bearing, or if you (or the mechanic) used an impact wrench while installing the new hub, you could have damaged that one as well.
Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
07-15-2006, 10:32 AM | #4 | ||
Thanks for the info so far. A while back, I had trouble with the car stalling out of the blue and you guys diagnosed it as a faulty crank position sensor. I brought it into the dealership and had them change it without doing a diagnostic test. They raised their eyebrows a bit after I told them I wouldn't need a new fuel filter, etc (or whatever else they were saying I needed). To make a long story short, thanks to you guys, the car does not stall anymore and I saved a BUNCH of money. Thanks again-Rodd |
07-15-2006, 12:04 PM | #5 | |
You're very welcome, we are always glad to help, and we appreciate the feedback too. We like to hear our advice helped you save some $$$$.
07-16-2006, 06:23 PM | #6 | |
i have the same problem on my '00 GT, track off and ABS light on all time, have not replaced nothing, what kind of hub bearing is, should i take to a mechanic or is something i can replace myself, or how much does it cost reparing?
thanks in advance
Mtpina '03 Mazda6s 3.0 '00 Grand Prix GT Del Rio, Tx |
07-24-2006, 06:51 PM | #7 | ||
Just replaced Pass. front wheel-hub assemb. in my 97 GP/GT just shy of $400 for diagnostics,parts/labor |
07-24-2006, 09:36 PM | #8 | ||
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
07-25-2006, 09:21 AM | #9 | |
This happened to me last month on my 97 GT. I had the dealer diagnose it, and then replaced the back driver hub with a refurbished one I bought on eBay for ridiculously cheap.
07-25-2006, 09:52 AM | #10 | |
mtpina, you need to take your car to a garage that has an ABS capable scan tool (the ones Auto Zone and Advance use are not ABS capable) to determine which wheel isn't sending a speed sensor reading to the ABS. Once you narrow down which wheel it is, if you're able to do your own brakes, you can do a hub bearing. You'll need a hub puller, 36mm hub nut socket (for the front hubs) and a good torque wrench capable of a 180ft/lbs setting (depending on what brand hub you buy) to do the job correctly. Whatever you do, DO NOT use an impact wrench on ABS sensor equipped hub bearings. The hammering action will ruin the ABS sensor and you'll be doing it again real soon.
07-25-2006, 10:08 AM | #11 | |
This is happening to my 99 GT. I bought it, had the problem, took it in, they fixed it, and it stayed off for a bout a week. I took it back, they fixed it again. This time it stayed off for about 2 months. From talking to other people that have had those cars, and a buddy that runs a dealership, this happens alot. YOu can keep going in and replacing the hub assembly or you can deal with it as it doesn't really affect the car other than the traction control does not work.
07-25-2006, 10:41 AM | #12 | |
I also am having this problem with my 1999 Grand am. I had a alignment done and the transmission fluid changed two weeks ago(not sure this has anything to do with it) since them my low trac light has been coming on whenever I start moving, then my ABS light and Trac off light come on and stay on. Does anyone know if having the alignment done could have caused this.
07-25-2006, 11:20 AM | #13 | ||
07-25-2006, 11:34 AM | #14 | |
I'd say at least half of wheel sensor problems is bad or damaged wiring. The electrical connector at the hub is subject to the elements/corrosion and a mechanic can BFFI the job up such as in an alignment or doing a brake job.
Therefore, do a thorough inspection of the wiring and electrical connector at all four wheels. Also, the wheel sensor can be ohmed out with a mulitmeter. Check for around 1K ohms at the wheel sensor contacts. Finally, the quality of the hub bearing is important. Garbage in garbage out.
07-25-2006, 02:14 PM | #15 | |
I did mine in March with AC Delcos that I got from Rich and have not had any problems from them.
