| Latest | 0 Rplys |
#1 | |
![]() Join Date: Feb 2005
p0102 code
ok 99 GP SE 3.8
been showing a p0102 code for a while i have changed the MAF sensor twice now cause each time the code would go away for a day or so and then it comes right back, ive already checked for like physical damages to wiring and harnesses and appears to be none, i would like to know if any one can help or provide me some information on what might be the problem or how to diagnose it that would be great thanks
#2 | ||
![]() Join Date: Jan 2005
Re: p0102 code
Is the car stock or any mods such as intake? P0102 DTC means MAF sensor low frequency. Possible causes are blockage at intake screen, vacuum leak at the intake manifold or throttle body, EGR valve flange leak. Also a defective or improperly sealed PCV valve. Try cleaning the throttle body. Check the reference voltage with a voltmeter at the yellow wire of the MAF sensor electrical connector plug for approx. 5 volts. After that you'll need to ohm out signal and ground wiring between the PCM and MAF sensor. Make sure the connector plugs on the PCM have no corrosion and are tight. The last item on the list if none of the above is a possible defective PCM. Good luck! ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
#3 | |
Do you have a K&N filter on the car. GM and ford are having problems with k&N filters shorting out the MAF sensors from the filter oil getting on the sensor and shorting them out and most of gm and ford dealerships will now void the warranty if you put a k&N on your car.
#4 | ||
Re: p0102 code
I could care less what GM will do to my warranty because it ran out back in 2001. ![]() ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
#5 | |
alright yeah its only going to affect warranties of 2004 and up. And most of the time it is people putting too much oil on it thats causing the problems. I have a thrasher cold air on mine and i never had a problem with mine.
#6 | |
ok so my post is a little deceiving,
the GP in the picture with the mods is not the one im talking about the car with the code is a 99 GP SE 3.8 as already stated and it is completely stock NO mods at all hopes that helps help me
#7 | ||
Re: p0102 code
