Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 04-24-2005, 12:21 PM   #1
formzy
Loose body-side moldings
I have a friend who owns a '93 Roadmaster that has the body-side mouldings falling off. It seems a common problem on these cars. The only fix is double-faced tape but it seems to loosen again within a year or so. I've cleaned both the molding and backing plate with prep-sol(grease and wax remover) and applied the tape but have been disapointed. Anybody know of another and possibly better way to re-attach these moldings? Thanks!
formzy is offline
Old 04-25-2005, 07:36 PM   #2
silverfox103
Lightbulb
Hi
I have a 95 Roadmaster which has had the same problem. This is how I cured it: Clean molding and chrome trim, then use silcon rubber in a tube; apply to rubber molding. Place rubber molding on chrome trim. Secure molding with masking tape until silicon has dried. I have done this for 3 years (piece by piece) and knock on wood molding is still secured.
Tom C.
silverfox103 is offline
Old 04-29-2005, 08:59 PM   #3
gn1220
Remove all of the rubber trim, clean the stainless of ALL glue residue, clean with Windex, polish to a nice shine and throw the rubber in the trash. My wagon looks much better without the falling rubber. I was going to put a wide black pinstripe, the same width as the rubber, back on to give the illusion the rubber was still there. Wouldn't have to worry about that falling off all of the time.
Buicks answer was to remove the wide trim and use sheet metal screws from the backside to attach the rubber.
gn1220 is offline
Old 11-23-2005, 05:40 PM   #4
KCC
Re: Loose body-side moldings
Double faced tape, glue, naw. I screwed mind on. I drill over size holes in a good location, put some countersink screws in and fill the hole with gray body putty. Painted the moulding and it looks great.
KCC is offline
Old 11-30-2005, 11:22 PM   #5
KatWoman097
KatWoman097's Avatar
My husband cured his moulding problems by shaving them off
NEW SIG COMING SOON
KatWoman097 is offline
Old 12-01-2005, 12:47 PM   #6
'97ventureowner
'97ventureowner's Avatar
Re: Re: Loose body-side moldings
I used to do that to some of the cars I've owned. Here in NY where they use a lot of salt on the roads in the winter,you'd be amazed at the rust and corrosion that forms behind the mouldings, especially those on the bottom of the panels, and doors.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline
Old 12-08-2005, 09:36 PM   #7
creid60
I have same problem on my 93, 95 and 96 roadmasters. This was another terrible GM trimdesign and like wood trim on wagons not made for the Harsh weather. First is to make sure you do not lose any molding by checking to see if any are loose. You can't get new ones very easy. The key to repair is to clean both rubber and metal very well. Use a low residue solvent with high cleaning capability. Once clean make sure surfaces are completely dry and it is not a humid day ( Hard to do if you like me and live in South). Winter is good time for us in South to do this. Buy 3M heavy duty GREY
exterior double stick tape from Home Depot or Lowes ( usually in the Paint department). Don't use white foam double stick tape. Use the Grey. Apply 2 strips of tape to cover rubber backing completely and apply to metal trim. This worked well for me and I have had to maybe only to fix again once or twice over the 10 years. I have these cars in rainy hot Florida(All Three are outdoor cars.). Remember that the key is very clean and dry surface at time of application to assure good bonding. Take the time to clean it and the tape will adhere with much better longer lasting result
creid60 is offline
Old 09-18-2007, 10:09 PM   #8
electricmanbob
I stuck my moldings back on with RTV silicone . That was 12 years ago...still holding!
electricmanbob is offline
Old 09-18-2007, 10:24 PM   #9
'97ventureowner
Please check the date of the last post and avoid posting in those over 90 days since last activity. If you have new info feel free to start a new thread and link to the old one. Closed.
Closed Thread
