Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-18-2012, 03:52 PM   #1
luvmyS10
A diy guy...if possible
luvmyS10's Avatar
95 camry barely runs
My sister's 95 camry died on her while driving.I got it here to my place and got it to start. If you try to accelerate it, it dies. if you press pedal slowly, it will go to about 3000rpms. If I go to fast it dies. It barely idles, maybe 300rpms and car shakes. I changed fuel filter, and she had timing belt changed maybe a year ago. Any ideas? it has the 2.2 4 cylinder, a lil over 230,000 miles on it. It runs better untill it gets to operating temp.
2003 GMC Sonoma crewcab 4wd
luvmyS10 is offline   Reply With Quote
Old 02-19-2012, 01:30 PM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: 95 camry barely runs
Check the codes. Most likely problem is the HO2 sensor or coolant temperature sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
The Following User Says Thank You to Brian R. For This Useful Post:
luvmyS10 (02-19-2012)
Old 02-19-2012, 02:39 PM   #3
Mike Gerber
AF -Advisor
In addition to what Brian suggested, I would also check the coil inside the distributor for cracks. You will probably have to remove the coil to inspect it for cracks. You can also check the coil for being in spec with a digital volt/ohmeter and the specs from any manual. However, many times they test in spec but still are faulty because of cracking. That's why I suggest removing it from the distributor and visually inspecting it for cracks.
Mike
Mike Gerber is offline   Reply With Quote
The Following User Says Thank You to Mike Gerber For This Useful Post:
Old 02-19-2012, 02:52 PM   #4
luvmyS10
luvmyS10's Avatar
The check engine light is not on, but will check for codes. Thanks
Old 02-19-2012, 02:55 PM   #5
luvmyS10
luvmyS10's Avatar
I changed gas filter and one thing i did notice. It would not pump fuel unless I was turning engine over. is this normal? Im used to chevys that prime fuel when the key is turned on.
Old 02-20-2012, 10:10 PM   #6
Brian R.
Resident Chemist
Brian R.'s Avatar
This is normal. That was a good idea about the ignition coil.
Old 02-27-2012, 04:41 PM   #7
luvmyS10
luvmyS10's Avatar
Smile Re: 95 camry barely runs
I removed coil and was replacing with a new one and the connector on the end of one of the wires fell off. wasnt crimped tight. I replace connector and put in new coil and all is well. Thanks to everyone
92 Bonneville, barely runs jusber15 Bonneville 24 05-19-2006 02:59 PM
91 Camry barely starts, engine misses & knocks RDMaddox Camry/Camry Hybrid/Vista 3 11-01-2005 10:06 AM
94 Lumina-Car stalled...now barely running mandodan Lumina 2 11-08-2004 09:34 AM
1996 Cavalier - cylinder 4 misfire, barely runs Steph Engineering/Technical 4 06-13-2003 02:08 PM
