Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue)
Old 03-28-2007, 10:21 AM   #1
BNaylor
BNaylor's Avatar
2000 and Up 3100 LIM Gasket Procedure
Here is a helpful link one of our members posted concerning performing a lower intake manifold gasket replacement on the GM 60 degree engines. This is applicable to both the 3100 VIN "J" and 3400 VIN "E". 2000 and up Pontiac Grand Prix with the 3100 have the VIN "J". Note: This specific procedure is not applicable to the 3100 VIN "M" found in 1999 and under Grand Prix although there are similarities.
Click here
Revised torque pattern and torque values for LIM bolts.
Engine Oil or Coolant Leak (Install New Intake
Manifold Gasket) # 03-06-01-010B - (10/24/2003)
Engine Oil or Coolant Leak (Install New Intake Manifold Gasket)
2000-2003 Buick Century
2002-2003 Buick Rendezvous
1996 Chevrolet Lumina APV
1997-2003 Chevrolet Venture
1999-2001 Chevrolet Lumina
1999-2003 Chevrolet Malibu, Monte Carlo
2000-2003 Chevrolet Impala
1996-2003 Oldsmobile Silhouette
1999 Oldsmobile Cutlass
1999-2003 Oldsmobile Alero
1996-1999 Pontiac Trans Sport
1999-2003 Pontiac Grand Am, Montana
2000-2003 Pontiac Grand Prix
2001-2003 Pontiac Aztek
with 3.1L or 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1)
This bulletin is being revised to change the model Information. Please discard Corporate Bulletin Number 03-06-01-O10A (Section 06 - Engine).
Condition
Some owners may comment on an apparent oil or coolant leak. Additionally, the comments may range from spots on the driveway to having to add fluids.
Cause
Intake manifold may be leaking allowing coolant, oil or both to leak from the engine.
Correction
Install a new design intake manifold gasket. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. When replacing the gasket, the intake manifold bolts must also be replaced and torqued to a revised specification. The new bolts will come with a pre-applied threadlocker on them.
Notice
An oil leak may result if the vertical bolts are not tightened before the diagonal bolts.
Diagonal bolts may require a crows foot to tighten.
Tighten
1. Tighten the vertical lower intake manifold bolts (1) to 7 N.m (62 lb in).
2. Tighten the diagonal lower intake manifold bolts (2) to 7 N.m (62 lb in).
3. Tighten the vertical lower intake manifold bolts (1) to 13 N.m (115 lb in).
4. Tighten the diagonal lower intake manifold bolts (2) to 25 N.m (18 lb ft).
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 07-27-2010, 11:31 AM   #2
Firstymer
Cool Re: 2000 and Up 3100 LIM Gasket Procedure
It seem pretty straightforward; my only concern or challenge is the revised torque pattern and torque values for LIM bolts. Do I need a special tool to that will allow me to tighten the bolts at a specified torque? Have you done a LIM gasket procedure before Bob or Tim? Please check out the picture I posted previous to determine that leaking orange residue...thanks a lot fellas for the info.
Firstymer is offline   Reply With Quote
Old 07-27-2010, 08:09 PM   #3
tblake
In God We Trust
tblake's Avatar
I have done a bunch of 3100/3400 LIM gaskets, a few 3800's, and a couple 5.7's on GM vehicles. You will definatly want to go with the fel-pro aluminum framed gaskets, make sure you get new bolts (fel-pro also carries these), and a 3/8 torque wrench is a must.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
Old 08-01-2010, 10:38 AM   #4
BNaylor
BNaylor's Avatar
Do you have a link to the pic? Orange is normally Dex-cool.
Timeslip 08/12/06
