View Full Version : Cavalier
- picture sig...
- Can somebody tell me what this is in my trunk and connected to my speakers?
- ignition mod on 89?
- new to the forum
- Tranny Problem 99 z24
- Exhaust idea
- Will spark plugs that I got for the 2.2 work well for the Z?
- drilled rotors, worth it?
- 96 Cavalier Motor Compatability
- capacitor?
- Final pics for the year, till next spring... Hopefully.
- Bad Coil Pack!
- dashboard
- Battery or alternator
- God damn it...
- my dreaded interior :(
- 97 Cavalier Cooling Fan
- Doors
- Question?
- Why Import Cars?
- proceedur for replacing head gasket???
- saftey feature for reverse
- Question for you 2200 Owners
- A day at the junkyard..
- Joining up
- 97 cavalier fuel problems
- Cluster ****
- Some pics from the car show
- ported vs sealed box difference
- 96 Chevy Cavalier
- annoying problem with brakes, suggestions??
- Chrome wheels Powdercoated??
- yellow headlights???
- Will these speakers wire up to my doors?
- how many qts of trans on a filter change?
- Cavalier with a 350
- Shift kit for an automatic
- Nitrous + Supercharger...safe?
- engine upgrade to a 3.8L from a 2.8L
- Z24 running rough!!
- check out this cavy!!!
- 2.2 to 2200 swap help
- Need Cavalier Info picking up my first one tomorrow. Please help.
- New clutch now we cant get it in gear! HELP!!
- Trunk Release...err not
- changed starter now car won't start??
- Plug gap 01 Cav
- As promised... RDFABS exhaust install.. Truly one off..( 56K will die)
- 98 cavalier abs light on
- 2001 torque converter switch
- 97 Cavalier 14,700 miles- Suggested Maintenance?
- Keyless Entry Problem
- Header Gasket
- Removing fabric on door panel? Also, the bezel around the handle?
- I Am SOOOOO going to this...
- Banter Thread
- double clutching...?
- Sunfire eyelids/hood?
- Problem With Radio
- AC Stopped Without Any Warning
- 2.2 timing issues
- 1998 Random missfire 2.4L engine
- 95 engine conversion
- Are these stock speakers?
- Cavalier '93 z24 coolerfan Max and Min temp
- This past weekends car show...56k. NO WAY!
- High pitch whining sound when in 1st, 2nd, 3rd gears??
- Speaker Sizes
- performance upgrade help
- should there be a ''off-topic'' subforum for cavalier
- Where's the A/C Low pressure switch located on 99' Cavalier?
- Possible way to wire?
- NOS question
- 91 cavalier heat up problem
- no transmission?!
- No Oil Is Responible For My cavy
- Can a 2.2 liter go into a 95 cavalier
- Just Checking
- wiring harness and antenna adapter ..Work?
- how to agust the hand brake on a 98 cavalier
- rear bumper reinforcement
- What car should I get a 96 civic or a 02 cavalier?
- cold air intake design
- front bumper
- changing fuel filter
- T3 turbo manifold
- check this out
- Inspired by Cody...
- MY ac problem
- Soo... I was Looking at some old pictures..
- paint code
- For a highly tuned performance motor - 2.4 or eco?
- crankshaft hub on cavalier
- Shocks and Struts
- cosmo racing website???
- Rims
- Problem starting
- 2.4l
- newb question from....... well... a newb.
- Interior Panels
- Rear Allignment
- anyone????
- The Official Rice Cop Tread.
- My Speedometer is not working !!
- Horn relay on '03 cavalier
- back Left turn signal
- Question?
- what state does everyone live in??
- airbag help please !!
- can't find any pics of my ride....HELP!
- 90 Cav 3.1 electrical problem
- ok antenna wire ripped *Pics* and progress
- need help high beams
- I need a explanation of head unit wiring
- Rear Brakes
- The check engine code
- Apology
- fuel fittings
- Coil Pack
- 2004 Cavalier AC Question
- 1997 Cavalier making strange groaning noise
- what happens when you run out of oil
- Question about larger motors and swapping
- need help fast before we go any further please!!!!
- Timing chain replacement cost for '97 Cavalier
- measurements of exhaust
- 96 Sunfire temp gauge moving up and down when driving?
- Transmission adapter plate for a 98 Z24?
- somebody help please and dont just respond with dumb messages
- 97 Cav Axel Change
- 97 cav stereo
- cobalt SS sc or srt-4???
- subs
- cavalier horsepower.
- SlUGGISH!!!!!!!!
- Need Advice On 1995 Cav!!!
- 1991 cavalier z24
- To jetaylorpb re Retro Cavalier
- fireing order
- significant upgrade from Cavalier?
- What is oxygen sensor for?
- difference between 2.3l and 2.4l
- Water pump replacement
- what is my cars problem ugh...
- spark plugs
- 2001 Chevy Cluster/Gauges Problem and Question
- track times
- killing the rust with a very good cheap product
- Its been fun...
- kickers....any good?
- what 4 w7's will do to the trunk
- Gauge Cluster Swapping?
- weak battery?
- W00t Finally Came
- track lites
- i raced a mitsubishi gallant tonite
- rota slipstreams
- '98 rear speaker removal help
- Where is the coolant temperature sensor???
- dies when coming to a stop
- 03 cavalier bogging in 1st and 2nd
- why did i win
- Your thoughts on this ignition set up?...
- Still no turnin over!!
- Surging Idle on '96 Z34
- 2001 Calvalier Wheel Bearings
- Where did the "Z" come from???
- temp problem
- 94 Cavalier Fuel Pressure?
- ¿Can anyone help?
- ABS light coming on over bumps...
- Track
- 99 cav serpentine belt
- Where is the DRL relay in a '97 cavalier?
- Question about belt
- Check out Zee DUUUBS... YO!
- 2003 cavalier - horn not working
- Body Parts - Does anyone know?
- Cavalier Opinions and Ideas
- 97 cavalier 2.2 stalling.. need a techs help.
- Home-Made Tire Rotation
- Perfect Launch
- Plugs, coils, plug boot inserts...
- Bleeding Cooling System on 97 Cavalier??
- where's the crankcase sensor located?
- Help: Guage Cluster
- spark plug wires
- 1997 Cavalier Loosing Coolant? Need Help!
- Big Day, Much Help Needed, 1989 Steering Column Job
- need help with 94 not starting
- Annoying High Speed Dash Noise
- Recommendation for Wheel size
- Why is my key getting stuck in the ignition??
- Lowered + Body kit + Need 4 alignment = PITA!!
- Radiator Fan Motor??
- Race Prep.
- random question bout cams...
- friggin finally
- Help finding knock sensor on a 98 Z24........
- Pictures
- posting pictures help?
- Help diagnose my problem!
- Header install
- ECU Replacement
- Hot Import Nights anyone?
- Funk Master Flex Car Show Pics!
- Real Dumb Fun
- Molding Inserts for 98 Z24
- want to buy Quad4DualCam !!!please help!!!
- Someone with a tach?
- nicely priced wheels...
- 1999 z24 auto tranny needs help
- Is the horn wired through the radio???
- Help with radio please
- Questions about my subwoofer in my cavalier
- compatibility
- Hands Down 2nd Annual Custom Car Show!
- z24 exhaust questions
- i need to no what is the name 4 euro lights
- Throttle body
- Gauge Cluster
- Z24 timing chain
- Transmission Problems
- Finally! Got the trunk and interior finished. Check it out!
- Difference between oil filters?
- '96 2.2 Engine R&R cost..
- Where Do I Find a WAI or CAI for an 89 L4 2.0 coupe?
- Bearing hub assy R/R
- looking for a video
- 1998 2.4 map vacuum line missing
- finally finished my interior paint!!!
- vinyl
- 89 Cavalier on SKINNIES
- BIG problem w/ my exhaust
- I need a favor... Anyone got like 5-10min to spare?
- P0442
- best prices on brakes?? (drums)
- Help!!
- Where to buy Fiberglass Materials???
- dash cluster conversion
- JUST developed a weird ticking..
- is this worth it
- Does A+ Performance send their own decals when you order from them?
- 87 cavy no injector pulse
- sideskirts
- Help Me Out...
- Help Me Out...
