Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-31-2002, 01:11 PM
lamasters lamasters is offline
Question questions 2 the neon experts
Q#1 is the 98 neon powered by mitsubishi?
Q#2 what r the modifications needed to get to 220hp
Old 09-01-2002, 03:49 PM
mattzneon mattzneon is offline
Send a message via AIM to mattzneon Send a message via Yahoo to mattzneon
Q1... Honestly I'm not sure 'bout that. I know Dodge and Mitsu are closely related, but not sure...
Q2... Turbo and every bolt on you can think of. In this months Sport Compact Car mag, they have 'Project Neon'. They upgrade 15hp with a mopar kit of cam and springs. But the previous addons include intake, exhaust, pullies, etc. Really, you should read it up. Its actually the 3rd article of the series... Check out Feb. '02 issue for the 2nd article, and I'm not sure about the 1st article. Anywho... To get 220hp you have to do a lot. A cam and simple bolt ons only bring it to 135hp. C'mon... 220 would include a nice shot of nitrous with a turbo. So, check that out. But I'd love to get mine to 220, but its gon' take a lot of bills. I'm looking into gettin' a custom trubo built shortly... They run cheaper than the Hahn Racecraft S1 or S2 turbos.
Matt
Old 09-02-2002, 11:07 PM
ZildjianRocker ZildjianRocker is offline
Banned
Let me tell you how to get to 200+hp
DOHC
HahnRacecraft Stage 4 turbo with front mount intercooler
Greddy Profec Electronic boost Controller w/ Profec switch
HKS turbo timer
HKs blowoff valve
JE turbo pistons and Eagle rods
8.8:1 compression
Crane turbo cams with titanium valve springs and retainers
MSD ignition
Pacesetter Exhaust
Magnecor Spark Plug wires
Iridium Spark plugs
Accel fuel injectors
56mm Bored throttle body
Ported and polished head
AFX underdrive pulley
Xenon body kit
17" Racing Hart Z5000
Mint Green
You tell me if you like this. If you do I will send you pictures
Old 09-05-2002, 06:59 AM
Heh... That 'mint green' ads an instant spray on 25.6 hp! I tried it! You go with 'navy blue' you spray on 30 hp! So choose your colors wisely.
Matt
P.S.
Just Kiddin'
Nice wip tho Ziljian
Old 05-05-2003, 08:50 AM
NEONACR98 NEONACR98 is offline
i HAVE A 98 NEON AND FROM MY UNDERSTANDING EVERY WEBSITE IVE BEEN AT SAID ITS THE DODGE DESIGN AND MITSUBISHI USED IT OR JUST ADDED THE TURBO
Old 05-05-2003, 09:46 AM
crankwalk 2g crankwalk 2g is offline
I used to work at a Dodge dealership and a lot of the cars had Mitsubishi engines in them, and the Neon and Eclipse gs share a similar engine but the GS-T AND GSX models don't just have a turbo ''added'' to them. Those models have a totally different engine layout and different specs and a turbo all made by Mitsubishi.
Old 05-11-2003, 09:29 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Also, Chrysler owns 85 percent of the voting stock of Mitsubishi. They have been doing this since the 80s, what makes you people so surprised?
Old 06-16-2003, 04:45 PM
czorrilla czorrilla is offline
That information is extremely important to me, could you tell me wich engine is the one in the 94-95 Neon that si the same of mitsubishi?
I'm thinking of buying a Neon, but people here (Dominican Republic)are afraid of buying the car because parts are expensive and hard to get, but if you tell me what engine model number is the one for Mitsubishi, then You will make a happy man!
Old 06-17-2003, 10:11 PM
Scatch! Scatch! is offline
The 420A in non-turbo DSM (Eclipse, Talon...) is the same short block as the Neon engine. The head on the DSM is different, though - front exhaust exit, rear intake.
The Neon engine is often (mistakenly) called the 420A, but it is the S4RE (SOHC - non-Magnum) and D4RE (DOHC). Because of the different heads used, they are not all the same engine. At least not exactly.
And unless I'm mistaken, the engine in the new MINI is more or less a 1.6L version of the Neon engine with yet another head.
Old 07-08-2003, 05:00 PM
neonfearme neonfearme is offline
Question neon and eclipse engine
can you use a turbo ment for a sohc eclipse with a neon?
Old 07-08-2003, 10:20 PM
Re: neon and eclipse engine
Sure as long as you can get a manifold to work with it. The SOHC Mitsu manifold will not bolt onto a Neon engine, SOHC or DOHC.
Questions for the Resident Expert JDM4LYFE Rutt Cars in General 5 03-13-2005 10:34 PM
A question for the Mercedes experts mikemechanic Car Modeling 1 03-18-2004 01:31 AM
Question for the photoetch experts :) The Lambrusco Kid Car Modeling 4 02-23-2004 08:50 PM
question for the pro's,experts if u will! ss1 Forced Induction 12 02-21-2004 11:32 PM
a question for the wiring experts... 20HondAccord02 Engineering/ Technical 2 01-12-2004 02:03 AM
