Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-23-2003, 12:17 PM
xt12345 xt12345 is offline
spark knock
I have a Xterra SE 4x4, 50,000 miles. When I'm driving uphill, I'm hearing a clicking noise coming from my engine. I believe it's called spark knock. I usually run Chevron 87 octane gas in my X. Should I check the timing?
Old 04-23-2003, 01:45 PM
evergreen's Avatar
evergreen evergreen is offline
try better gas.
switch to a different brand and up the octane.
Beer me!!
Old 04-24-2003, 09:09 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Very mild knock under load is normal and actually when you're at your max efficiency (as stated in your owner's manual) but if it's more than minor, you should try fiddling with your gas brand and/or octane to see if it goes away. If it does, consider checking your timing (detailed in the how-to section here) but confirm the spec for your model year first.
Brent
Old 04-24-2003, 09:50 AM
Thanks
Thanks for the input. I will do some research through my manual.
Old 04-24-2003, 11:56 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Timing has been known to be off straight out of the factory.
Xterra4x4.com and the Xterra Offroad Webring
92 EB spark knock. Has new open air intake hallboy Explorer | Explorer Sport Trac 3 02-12-2004 05:43 PM
Spark Knock ( pinging at low speed ) mcgiverohno Eldorado 2 12-19-2003 09:38 AM
how do I fix my spark knock natekain Blazer 2 12-10-2003 01:29 PM
Spark knock Clay Miner General Discussion 0 12-04-2003 10:24 AM
spark knock joeemy General Discussion 1 11-15-2003 06:43 AM
