| Politics, Investments & Current Affairs Yea... title kind of explains what this forum is about. |
Alternative oil source
Resistance Is Futile (If < 1ohm) |
Sounds like a good idea to me...I'm sure this will piss of PETA.
*Under Construction - New sig to debut* |
I don't buy it. Specifically, I don't believe it can give you back anywhere near enough potential fuel stock to be on the upside of the energy equation; meaning it takes more energy to drive the system than you get back in fuel. I can't think of a single technology man has invented using heat or pressure that is actually on the upside of the energy equation, and this is the problem that really has to be solved in order to find a renewable energy source that works, and works for good. Fusion may be the answer, but thus far nobody's been able to get more energy out of a fusion reactor than they put into it. In fact nobody's even near near the zero offset mark yet.
So I am basically assuming that a process which normally takes hundreds to thousands of years to complete in nature, with the constant invesment of heat and pressure energy (as well as natural catalytic conversions and bacterial interplay), is not capable of being reproduced in a few hours without an enormous investment in energy.
'03 Corvette Z06 '99 Prelude SH |
sounds intresting...but i'm skeptical.....wonder how much fuel this machine is using and how much pollutents it is creating
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
The carbon in the stock has a ton of energy ready to be used.
Basically I'm asking how long is this system sustainable without new sources of power? Let's try the experiment another way, rather than getting our power to heat and pressurize the system from outside sources, let's start with one full batch of refined product from the machine and put it back into the system. Process another full batch and let's see how much of the original we have left over. If there is any left then we have a system with a positive net energy equation; if we instead can't produce as much output as the original input (my contention) it's just another example of humans wasting energy. If the system is not ultimately self sustainable, there is no point in talking about it solving any of our energy problems. It definitely does turn wasted turkey guts into much better products, but we still have the age old problem of eventually running out of energy. Ps- You also have to consider all the energy it takes to produce the turkey guts, harvest them into one area and transport them to the machine. From start to finish, every venture for producing energy costs more than it nets except for solar cells, wind machines and hydro plants.
I personally think harnessing the Earth's magnetosphere is the ultimate answer, along with perhaps some future forms of harnessing solar power.
Just like in nature, this machine works like a cycle. In nature, you have a food chain, one animal dies, another eats it, gets energy, and dies, another animal eats it, etc etc etc. You just need something to start it going. Waste will always be an abundant resource. It takes several years to decompose a plastic bottle even. The article said that some of the the gas will go back into the machine, powering it, and you get the remainder of product from the machine which can be sold or whatever. You energy comes from the waste. It's not something that sustains itself totally with energy leftover, but it's a damn good step to getting there. I figure if we can clean up landfills with this, and turn them into something useful, then it's worth it.
I think some thought should go into gravity as a power source as well. It takes energy to lift your arm and hold it there, but it takes the same amount of energy to push down on your arm in the form of gravity.
![]() Soon.. Cars: 1990 Nissan 300zx Twin TurboSold Cars: 1976 Jaguar XJ-S - Rear end Donor to Chev Pickup |
Unfortunately gavity itself is an extremely weak force (probably the weakest in all of physics), that's why I mentioned the magnetosphere; it's a much stronger force.
"If you have built castles in the air, your work need not be lost. That is where they should be. Now put the foundation under them." ---Henry David Thoreau "And shepherds we shall be, for thee my lord for thee. Power hath decended forth from thy hand so our feet may swiftly carry out thy command. And we shall flow a river forth to thee and teeming with souls shall it ever be. In nomine Patris, et Filii, et Spiritus Sancti." ---Murphy and Conner MacManus |
I this is true it will reduce development into new fuel sources.
I don't mean something that is cleaner i don't care about that i am talking about subtances that produce lots of energy in small quantites and the developement of new engine designs (not the internal combustion) but something else that'll produce lots of thrust force torque whatever that can move something large with relative ease. Anyways it would screw up the OPEC cartel
Qualified Automotive Engineer
On thing to remember with the energy needed to get the raw materials is that they are using pre-existing waste products. There is no additional cost to producing them, as they would be there already. The only possible added costs would be in buying (which I don't see as a problem right now, but will be in the future as people realize they can make money off of their garbage) and transporting the raw materials. Even if those costs become significant, there is still a great benefit to just being able to do something useful with all of the trash. There is tremendous potential in this machine. If it performs as well as they state, great, wonderful. If not, it is still providing a very valuable service, and I would be willing to invest in it. On another thought... this might be interesting to use as a death penalty... get something useful out of all of those death row criminals that we're paying for...
They have to pay for it to be taken away already they'd probably let it go for free
200 tons of turkey waste a day is a lot of turkey parts; however I do not believe that the oil produced by this type of source would be near enough to take care of even one major cities needs.
